Debouncing with IRQ
dubaleeiro
Re: Debouncing with IRQ
Post by dubaleeiro » Sun Mar 04, 2018 3:07 pm
Now I see... thank you very much !
what would be the best way to break the while True loop throught this interrupt? Based on the Pin.value() or does the DebouncedSwitch object has some debounced Pin state?
Thanks a lot for you patience and guidance :D
SpotlightKid
Post by SpotlightKid » Sun Mar 04, 2018 6:39 pm
Several possibilities:
1. Set a global flag variable in the callback function and check for this in the conditional of a while loop:
flag = False
def cb(dummy):
    global flag
    flag = True
sw = DebouncedSwitch(pin, cb, "dummy")
while not flag:
    do_something()
flag = False
2. Use a mutable for the callback arg and change that within the callback:
flag = [False]
def cb(flag):
    flag[0] = True
sw = DebouncedSwitch(pin, cb, flag)
while not flag[0]:
    do_something()
3. Or the same principle using a class as the callback arg and setting/checking an attribute on it.
alexholman
Post by alexholman » Tue Oct 30, 2018 1:49 am
Any suggestions for adapting this code to work from the analog input with a threshold?
On a NodeMCU I've gotten it working a simple push button, but I'd like to adapt it to trigger from a piezo sensor. Wiring it the piezo to the input pin works, but requires hammering on the piezo, and I know from experience that it can be way more sensitive wired to an analog input with a trigger threshold set. Reading the ADC with machine.ADC(0) is easy enough, but when I try to pass the resulting object to DebounceSwitch I get an error for missing .irq method. I see that the incoming sw object needs a 'callback' method or defaults to .irq. Any suggestions for what my callback for an ADC object would be and how to set it?
