Custom modules in v1.9.4-443 firmware now boot.py and main.py won't load
I was running into some memory issues so I added a couple of my modules to `/modules` before creating a custom firmware.
Flashing and running into the REPL via serial works just fine. However, I'm no longer able to run a `boot.py` or a `main.py`
My custom modules are there, and they work as expected, but those files are ignored and it always dumps right into the REPL.
[code]
PYB: soft reboot
Activated UART(0) for REPL
MicroPython v1.9.4-443-gc1c798f on 2018-08-10; ESP module with ESP8266
[/code]
Help?
[code]
PYB: soft reboot
[/code]
Help?
A couple of tests
If you enter
are your frozen modules listed? If so, they have been compiled into the build.
What happens if you edit main.py to read
and issue ctrl-D to soft-reboot?
>>> help('modules')
print('In main.py')
Re: Custom modules in v1.9.4-443 firmware now boot.py and main.py won't load
Did you place boot.py and main.py into frozen bytecode too, or did you leave it in the flash file system?
I didn't freeze them, and I did change them to minimal print statements only....they're just never picked up and ran.
Hello. I'm starting with micropython and i have same problem. When iwas using firmware downloaded directly from Site i have no problem with runing boot.py after restarting board. But when i compile firmware with added modules, ESP start to ignore boot.py which is in flash ...
Please can somebody tell me how to fix it?
boot.py and main.py have to reside in the file system.
They're just never "picked up" if you create your own firmware build.
They're on the file system but never ran.
File system? what you mean by that?? boot.py and main.py must be "fozen" in firmware??
When i was trying "Hello word" app, with orginal firmware from Site, i upload boot.py to board using mfpshell. And everything was Ok. but now with my own compiled firmware, boot.py don't run.
boot.py and main.py must not be frozen. The ESP8266 has a small FAT file system, which can be used to store data files and scripts.
I have boot.py in FS but ESP always boot to REPL and my boot.py is not started.
