wtf main.py and boot.py empty?!
I managed it now to write data to the sd-card, but when i remove it: boot.py and main.py are empty?
Then I wrote scripts in there again and repeated procedure, they becam empty again.
Can i manage it to use boot.py and main.py from the sd-card?
Re: wtf main.py and boot.py empty?!
Sure. If main.py and boot.py are on the sd card, they will be used. What you see may be a problem of the sd-card being attached as a PC drive. Then data may look as if being on the sd card, but is still is in the cache. Take care that you eject that drive always. On linux, use the sync command to force cached data to be written.
Thanks.
Is there any overview of boot process or enabled devices while starting up?
my main.py:
this works:
pyb.delay(2000)
f = open("/sd/schrott.txt", "a")
f.write(str(pyb.millis()) + "\n")
f.flush()
f.close()
f = open("/sd/schrott.txt", "r")
f.read()
uos.sync()
pyb.LED(3).on() # indicate we are waiting for switch press
pyb.LED(4).on() # indicate that we are selecting the mode
and this works not (no delay):
f.flush()
f.close()
f.read()
uos.sync()
So your system needs still some time after booting to have working filesystem.
this works:
pyb.delay(2000)
f.flush()
f.close()
f.read()
uos.sync()
f.flush()
f.close()
f.read()
uos.sync()
This is not plausible, since main.py is also executed form sd. To be sure, that there is no interference with the PC file manager, change boot.py like below, disabling the device as storage device. It will then not mount any more at your Pc as drive. This is inconvenient, but saves you from a lot of trouble.
#pyb.main('main.py') # main script to run after this one
#pyb.usb_mode('CDC+MSC') # act as a serial and a storage device
pyb.usb_mode('CDC+HID') # act as a serial device and a mouse
#pyb.usb_mode('CDC') # act as a serial device and a mouse
I'm doing some analyzation:
my boot.py:
q = pyb.micros()
p = pyb.micros()
k = pyb.micros()
pyb.usb_mode('VCP+MSC')
pyb.main('main.py') # if switch was pressed, run this
pyb.LED(4).off() # indicate that we finished selecting the mode
pyb.LED(3).off()
and as you know:
q-p is 10us
and k-p is 36us
So i assume, the reason for something normally taking ~50ns is taking 10us, is the time for interpretation of python code.
So My suggestion is a completely new language for writing bytecode
my boot.py:
q = pyb.micros()
p = pyb.micros()
k = pyb.micros()
pyb.LED(3).off()
and as you know:
q-p is 10us
and k-p is 36us
Whatever you like ....
when i push the rst button electricity becomes visible ...
if you can manage it to directly interprete c-code this has great value.
I remember to have tried a C-Code interpreters in the past. It combined the disadvantage of compiled code and interpreted code.
No. You cannot easily compare compiled C code and Python Code and blame Python for being slow without blaming compiled c code to be unsafe. Python provides a lot of convenience in data structures and safety in execution, and that does not come for free. If you have specific section of your code with a need for speed, MicroPython allows you to get that with the different code emitters, from native code, viper emitters and assembly code. @pythoncoder has written an excellent documentation about that. You'll find it in the docs: http://docs.micropython.org/en/latest/r ... ython.html
