[Solved] Can't access REPL on macOS - Works on Windows
Re: Can't access REPL on macOS - Works on Windows
Post by Roberthh » Thu Dec 06, 2018 8:52 pm
Ok. Has the terminal program settings for flow control, which could be set to none?
b.t.w.: which terminal programndo you use? For convenience I use picocom. screen seemed overfeatured for my purpose.
Qetesh
Post by Qetesh » Fri Dec 07, 2018 8:46 am
I.... think I found a solution I can work with.
None of the different terminal programs I tried were working... but I just now installed the MicroPython plugin for PyCharm - and that works! I can access REPL and I can upload files through it.
But, when I start REPL I get a lot of garbage first before the prompt appears. I don't think that should happen?
It seems to work normal after that so I can ignore it I guess... but still would be nice to fix that :)
Device path /dev/tty.Repleo-CH341-001314FD
Quit: Ctrl+] | Stop program: Ctrl+C | Reset: Ctrl+D
Type 'help()' (without the quotes) then press ENTER.
{$d��|�l�|
          �l�
             #<����r�b�
                       b��go�$go���
                                   cp��d{l{lx�o�
                                                 d
                                                  cg�|�l$
                                                         c��go�$��d`�o
        �$or�ۓo
        c
        d`p�'�
        r�����
        b
        n�<l$
        c��'o��l �n
        $`o;�ۓo
        �$�dp�'�
        ;������s�
        n�<��
        b��go�
        $`�n
        �$or�ۓold`;��'
        ␍��<��π⎼┼␌��┌
        ␌��ܜ��$�␌�┌⎼␍ll��|��;so#��ld�d
        c��c��ܜ�#�
        c��ds$�l��|��{gb��l��c�
        c䌜���c�l#d���'�;��'|�lldl c��|;�d�'��o�l`��s�l�l�
        l`��s�l�l
        l`��r�l���
        dl {l��r$���c
        ��#|l#��#<����
        dl#��o�o��lg�
        $�l$���
    l`�g�����c
              $l䌏c���c
                       d
                        �csdsds�'����c�;�l�x�d��
                                                �x���d�c��g�߀�c��{�$�x�l���x���ds$�l��|��{gb��
        �����c�
        c䌜��<��cd
        dcl��l'�d`Ãdo�x{l�l��|��;gc��
        �#5 ets_task(40100130, 3, 3fff83ec, 4)
WebREPL daemon started on ws://192.168.4.1:8266
WebREPL daemon started on ws://0.0.0.0:8266
Started webrepl in normal mode
MicroPython v1.9.4-8-ga9a3caad0 on 2018-05-11; ESP module with ESP8266
Post by Roberthh » Fri Dec 07, 2018 9:26 am
The garbage at the startup is normal. The ESP8266 boot ROM send it first messages at a baud rate of about 74800 baud.
Qetesh
Post by Qetesh » Fri Dec 07, 2018 10:18 am
Ah good to know - thank you very much! Then I guess this thread can be seen as solved :)
