Interrupt variable increment problem
Nikunj_Vadher
Post by Nikunj_Vadher » Sat Jan 12, 2019 9:15 am
import config
itemp=config.temp
ihum=config.hum
def inctmp(p):
  itemp = itemp + 1
def dectmp(p):
  itemp = itemp - 1
p0 = Pin(0, Pin.IN)
p0.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=inctmp)
p15 = Pin(15, Pin.IN)
p15.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=dectmp)
here config.py file stores 2 variables temp and humidity
whenever try to do hardware interrupt using push button getting following error.
File "<string>", line 24, in inctmp
NameError: local variable referenced before assignment
I am using itemp and ihum in other code.
kevinkk525
Re: Interrupt variable increment problem
Post by kevinkk525 » Sat Jan 12, 2019 11:01 am
That's a basic python problem. I recommend reading tutorials.
The solution however is to do this:
def inctmp(p):
    global itemp
    itemp = itemp + 1
Kevin Köck
Micropython Smarthome Firmware: https://github.com/kevinkk525/pysmartnode
