I am stuck...
I have been working with my PyBoard V1.1 for a day now (just got it yesterday from Adafruit). I updated to pybv10-thread-20171101-v1.9.3.dfu and I have not heard from it since.
I used commands similar to below to update it. The log below is me restoring to pybv10-20170823-v1.9.2.dfu
With the DFU jumper in (BOOTP connected to 3.3V) it can be seen in the device manager as "STM32 BOOTLOADER". When the jumper out: "USB device not recognized The last USB device you connected to this computer malfunctioned, and windows does not recognize it. " is reported by the operating system (Windows 10 Home).
I have also performed the "factory reset procedure" to restore files system to a known state. (found here: https://docs.micropython.org/en/latest/ ... #safe-mode)
Is my board toast? BTW, I get the same results when plugging into several other computers. What is strange is that it works in bootloader mode, so I don't think there is anything wrong with the hardware. Also, the ST SfuSe Demo (v3.0.5) does not list any available DFU Devices.
[Additional information]
When looking at the device details in the Device manager it reports, "Unknown USB Device (Device Descriptor Request Failed)"
Anyone?
Rich
C:\Users\richa\Downloads\dfu-util-0.9-win64\dfu-util-0.9-win64>dfu-util.exe -l
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Cannot open DFU device 17e9:4323
Found DFU: [0483:df11] ver=2200, devnum=50, cfg=1, intf=0, path="1-2.4.3.1", alt=3, name="@Device Feature/0xFFFF0000/01*004 e", serial="367D32613036"
Found DFU: [0483:df11] ver=2200, devnum=50, cfg=1, intf=0, path="1-2.4.3.1", alt=2, name="@OTP Memory /0x1FFF7800/01*512 e,01*016 e", serial="367D32613036"
Found DFU: [0483:df11] ver=2200, devnum=50, cfg=1, intf=0, path="1-2.4.3.1", alt=1, name="@Option Bytes /0x1FFFC000/01*016 e", serial="367D32613036"
Found DFU: [0483:df11] ver=2200, devnum=50, cfg=1, intf=0, path="1-2.4.3.1", alt=0, name="@Internal Flash /0x08000000/04*016Kg,01*064Kg,07*128Kg", serial="367D32613036"
C:\Users\richa\Downloads\dfu-util-0.9-win64\dfu-util-0.9-win64>dfu-util.exe --alt 0 -D C:\Users\richa\Downloads\pybv10-20170823-v1.9.2.dfu
dfu-util 0.9
Match vendor ID from file: 0483
Match product ID from file: df11
Opening DFU capable USB device...
ID 0483:df11
Run-time device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 2048
DfuSe interface name: "Internal Flash "
file contains 1 DFU images
parsing DFU image 1
image for alternate setting 0, (2 elements, total size = 324016)
parsing element 1, address = 0x08000000, size = 14940
Download [=========================] 100% 14940 bytes
Download done.
parsing element 2, address = 0x08020000, size = 309060
Download [=========================] 100% 309060 bytes
Download done.
done parsing DfuSe file
USB device not recognized The last USB device you connected to this computer malfunctioned...
Re: USB device not recognized The last USB device you connected to this computer malfunctioned...
Thanks. A rookie mistake.
I am back in business.
Hi RWLTOK, what was the solution to your problem here? I am having the same issue now...
I loaded the wrong firmware image.
