Benchmark comparison of MicroPython boards
ckuehnel
Re: Benchmark comparison of MicroPython boards
Post by ckuehnel » Mon Mar 11, 2019 10:07 am
PyStone result for MAiX BiT w/ MicroPython v0.1.1 (CPU clock 403 MHz):
>>> os.uname()
(sysname='MaixPy', nodename='MaixPy', release='0.1.1', version='v0.1.1 on 2019-02-20', machine='Sipeed_M1 with kendryte-k210')
>>> exec(open('pystone_lowmem.py').read())
Pystone(1.2) time for 500 passes = 98 ms
This machine benchmarks at 5102 pystones/second
rcolistete
Post by rcolistete » Mon Mar 11, 2019 7:05 pm
Thanks, so I've updated the 1st post with benchmarks on Pyboard D, ESP32 and MAiX BiT.
scruss
Post by scruss » Thu Jul 30, 2020 12:57 pm
I don't think there's one in the table for the ATSAMD51, so I ran these on the Seeed Wio Terminal:
Seeed Wio Terminal (120 MHz ATSAMD51P19A, MicroPython 331f7c9-dirty on 2020-06-30; Ardupy with seeed)
pystone_lowmem:
Pystone(1.2) time for 500 passes = 339 ms
This machine benchmarks at 1474 pystones/second
('from utime import ...' changed to 'from time import ...' for compatibility with Ardupy)
performanceTest:
>>> performanceTest()
Count:  2192872
hsquare:
>>> Doing 50000 calculations...
calculations done after 7372 ms.
Mean time for each inverse h square calculation = 147.4400043487549 us
The Wio Terminal claims to support a 200 MHz mode, but Ardupy doesn't seem to expose any frequency control through standard libraries.
CircuitPython is much faster. It may be running at 200 MHz:
Adafruit CircuitPython 6.0.0-alpha.2 on 2020-07-23; Seeeduino Wio Terminal with9
pystone_lowmem:
Pystone(1.2) time for 500 passes = 352 ms
This machine benchmarks at 1420 pystones/second
performanceTest:
Count:  582628
hsquare:
calculations done after 3200 ms.
Mean time for each inverse h square calculation = 64.0000009536743 us
Sum of inverse h square = 37885.3893280029297
Mean of inverse h square = 0.7577078342438
