I can't access microSD cards with Pyboard 1.1
ThomasChr
Re: I can't access microSD cards with Pyboard 1.1
Post by ThomasChr » Tue Apr 16, 2019 5:43 pm
The problem is that the chinese people "forgot" to connect the Pin A8 which is the SD Detection Pin.
I assume they opted for a cheaper microsd connector which simply does not have such a switch (0.00 Cent saved!).
You can use your SD-Card like so:
mport os
# Forces the pin low, which tricks the board into thinking that an SD Card is connected
# Normaly there is a hardware switch for that, but on the crow board it seems to be left out
# If ommited os.mount() won't mount the sd card (even if present) with OSError: 16 (EBUSY)
machine.Pin('A8', mode=machine.Pin.OUT, pull=None)
# Now mount the sd card
sd = pyb.SDCard()
os.mount(sd, '/sd')
# Now you can work with the SDCard as usual...
os.listdir('/sd')
It seems that the mounting stopped when sd.present() is False.
Unfortunately I've not found the piece of code where that happens to see if there is some kind of force-Option to ignore if the sd card is resent and try anyway!
As an Alternative you can access the SD Card by hand with an SDCard Module... there are some out there.
You can read where the SDCard is connected in the Pyboard Shematics.
oserror
Post by oserror » Tue Apr 16, 2019 6:21 pm
@ThomasChr:
Great detective work! I just successfully mounted a microSD card in the REPL.
Did you figure that out by looking at the schematic? I looked at some of their documents but I didn't learn anything.
I can see how I could just add this code to the /flash/boot.py to perform this operation, and that will certainly work. I was able to load a program on the sd card with just an import statement, so the path is all set to go.
For now, that workaround will do the job nicely. I was getting a little worried that I'd have to locate a brand-name Pyboard 1.1 -- they seem to be very scarce and the Amazon sellers are selling them for a costly sum.
Thanks a lot for digging into the problem!
ThomasChr
Post by ThomasChr » Tue Apr 16, 2019 6:27 pm
I though that maybe they forgot one pin on the hardware side, and after looking at the schematic I remembered that there are two kinds of microsd connectors, with and without detection switch.
So I tried to forcefully change the detection pin and it worked :-)
The next step would have been to use a sd card library where you can init with the Pins from the schematic and so don‘t need os.mount()
Keep me posted if you can figure something out in the C-Code. The automount is in main.c and uses something like is_sdcard_present() to check if automount should occur.
But where exactly os.mount() happens in the C-Code and where the hell it checks if the SDCard object it‘s getting is present() - I have no clue...
Thomas
oserror
Post by oserror » Tue Apr 16, 2019 6:47 pm
I merely put these lines into boot.py:
# omitting your comment for brevity
# execute main.py on sd card
pyb.main('/sd/main.py')
and the async led flasher ran, with the uasyncio library on /sd/lib/uasyncio.
This is pretty darn close to what I want anyway with my regular code. It would be great to be able to see the sd card mounted in Linux, but it's not a deal breaker.
I'll look at the C-code but I'm not sure what I'll accomplish. If I swing the C-equivalent of a monkey wrench, I may fix something by percussive maintenance. :P Anything's possible! I have a feeling that a finer tool set may be required.
oserror
Post by oserror » Tue Apr 16, 2019 7:23 pm
You know, I'm looking at this code in main.c: (line 646)
    bool mounted_sdcard = false;
    #if MICROPY_HW_SDCARD_MOUNT_AT_BOOT
    // if an SD card is present then mount it on /sd/
    if (sdcard_is_present()) {
        // if there is a file in the flash called "SKIPSD", then we don't mount the SD card
        if (!mounted_flash || f_stat(&fs_user_mount_flash.fatfs, "/SKIPSD", NULL) != FR_OK) {
            mounted_sdcard = init_sdcard_fs();
    #endif
It looks like you'd just have to eliminate that 'if' statement:
    // The Crow Pyboard can't detect an SD card so let's forge ahead
    #endif
init_sdcard_fs() returns a boolean. It's already checking to see if the fs is viable. The question is, is it robust enough to handle when there is no card present at all? For questions like these, I have to use the monkey wrench (compile the firmware and test). I am not sure if it will crash or not. If init_sdcard_fs() can't handle it, then the C equivalent of 'try/except' would have to be added, which would be trivial for an ace, not so trivial for me but I'd try it.
ThomasChr
Post by ThomasChr » Tue Apr 16, 2019 7:29 pm
I would have done the exact same think. After a little bit of testing you surely will know if it‘s stable enough.
oserror
Post by oserror » Tue Apr 16, 2019 9:04 pm
I tried it. I have to leave the house in a few minutes, so I'll have to put this off for a while, but my initial test was to power up the Crow Pyboard with the altered firmware and no SD card.
I'll give it another shot later.
That is, it didn't boot.
oserror
Post by oserror » Tue Apr 16, 2019 11:17 pm
Okay, the issue was that I was compiling for the defaulted Pyboard 1.0. I changed that in the very top of the Makefile.
Using @ThomasChr's hack, I was able to patch the code in one place in the sdcard.c file, line 174:
    mp_hal_pin_config(MICROPY_HW_SDCARD_DETECT_PIN, MP_HAL_PIN_MODE_INPUT, MICROPY_HW_SDCARD_DETECT_PULL, 0);
Change that to:
    mp_hal_pin_config(MICROPY_HW_SDCARD_DETECT_PIN, MP_HAL_PIN_MODE_OUTPUT, MICROPY_HAL_PIN_PULL_NONE, 0);
and compile. I just made an Arch Linux VM as the dependencies were listed for that distribution, but it certainly would have built in some other flavor. I didn't even see a warning and it took about 2 minutes.
Instructions are at the Github page near the bottom. I had to also do a small substitution (as found when searching for the name resolution error on the git issues pages) to avoid a problem with the first step. This must be done right after the git clone.
sed -i -e 's|gnu\.org/r|nongnu.org/git|' .gitmodules
Your mileage may vary; I could not resolve that particular internet address.
I hope this patch helps someone else. I do enjoy it when something works!
jamonda
Post by jamonda » Thu May 21, 2020 3:53 pm
Hi, friends.
I bought this clone:
https://br.banggood.com/Pyboard-MicroPy ... rehouse=CN
I can't get the micro sd card to work. The workaround described here does not work.
Can anybody help me?
