derived class from socket
chastings
Post by chastings » Sun Apr 28, 2019 5:16 pm
It seems I can't derive from socket, and I can't figure out why.
First, a simple inheritance example with my own classes in micropython as a sanity check:
>>> class base:
... def foo(self):
... print( "foo" )
>>> class derived(base):
... pass
>>> d=derived()
>>> d
<derived object at 3fff1c90>
>>> d.foo()
foo
Now, the same example with socket...
>>> import socket
>>> class dsocket(socket.socket):
... pass
>>> d=dsocket()
>>> d
<socket state=0 timeout=-1 incoming=0 off=0>
>>> s=socket.socket()
>>> s
The derived object seems to have the same type as an object of the base class, which is unexpected.
Anyone know what's going on here? Happens in both releases 1.9.4 and 1.10. Thanks!
kevinkk525
Re: derived class from socket
Post by kevinkk525 » Mon Apr 29, 2019 5:52 am
Subclassing built-ins can sometimes work - but it's best avoided as behaviour is not guaranteed.
Doesn't work for machine.Pin either.
Kevin Köck
Post by pythoncoder » Mon Apr 29, 2019 6:28 am
It's worth reading this doc which explains the differences between MicroPython and CPython.
The problem with subclassing buiiltins can usually be worked around by using composition rather than inheritance.
