ESP8266 goes down after sometime [SOLVED]
Re: ESP8266 goes down after sometime
Given that your main loop runs every 180s I think you need to change the WDT time from 120s to (say) 300s. You should then be able to place the feed() statement in your main loop. I'd suggest after the while(True) statement.
The way a WDT works is that it resets the board if it is not fed during its timeout period. So, with the above change, the main loop should always feed it within five minutes. If the code stops running this won't occur and the board will be reset.
Now i get it, i need to feed in the loop, ok.pythoncoder wrote: ↑Tue May 07, 2019 10:05 amGiven that your main loop runs every 180s I think you need to change the WDT time from 120s to (say) 300s. You should then be able to place the feed() statement in your main loop. I'd suggest after the while(True) statement.
btw, esp8266 still getting down after i've changed a power source. So it's a software problem or mcu hardware problem.
Meanwhile, i am rewriting new python code on my esp32 and after i finished it, i will upload new code with your correction on esp32 and esp8266 both. Thank you, pythoncoder!
P.S. I've recheck, that esp8266 get into work after i pushed reset button. So, i believe mcu.reset should work.
damn. its still go to sleep. Even with your WDT.
Uptime was 1 day. Any ideas what it may be?
I will put it on notebook and will see whats happening on terminal, maybe i will see some debug.
import bme280_float
import micropython
class WDT:
def __init__(self, id=0, timeout=300):
self._timeout = timeout / 10
self._counter = 0
self._timer = machine.Timer(id)
self.init()
def _wdt(self, t):
self._counter += self._timeout
if self._counter >= self._timeout * 10:
print("WDT timeout")
machine.reset()
def feed(self):
self._counter = 0
def init(self, timeout=None):
timeout = timeout or self._timeout
self._timer.init(period=int(self._timeout * 1000), mode=machine.Timer.PERIODIC, callback=self._wdt)
def deinit(self): # will not stop coroutine
self._timer.deinit()
wdt=WDT()
WiFi_SSID = "ssid"
WiFi_PASS = "pass"
SERVER = "mqtt.thingspeak.com"
CHANNEL_ID = "77"
WRITE_API_KEY = "xxx"
led = Pin(2, Pin.OUT)
# Exception in an ISR should be handled, reserve memory for that
def do_connect():
wlan.active(True)
if not wlan.isconnected():
print('connecting to network... ')
wlan.connect(WiFi_SSID, WiFi_PASS)
print
while not wlan.isconnected():
pass
print('network config:', wlan.ifconfig())
print('SSID: ', WiFi_SSID)
def collectData():
temp1, pas1, hum1 = bme.values
#temp1 = result[0]
#hum1 = result[2]
hum1 = hum1.replace("%", "")
temp1 = temp1.replace("C", "")
led.on()
return temp1, hum1
# esp8266 scl pin 5, sda pin 4
# esp32 scl pin 22 (gpio 22), sda pin 21 (gpio 21)
i2c = machine.I2C(scl=machine.Pin(5), sda=machine.Pin(4))
#bme= BME280(i2c=i2c, mode=BME280_OSAMPLE_8, address=BME280_I2CADDR)
bme = bme280_float.BME280(i2c=i2c)
client = MQTTClient("umqtt_client", SERVER)
topic = "channels/" + CHANNEL_ID + "/publish/" + WRITE_API_KEY
ap_if = network.WLAN(network.AP_IF)
ap_if.active(False)
wlan.active(True)
pass
wdt.feed() # feeding a reset timer
temp1, hum1 = collectData()
#esp8266 bme code: payload = "field1="+str(hum1)+"&field2="+str(temp1)
print(payload)
client.connect()
client.publish(topic, payload)
client.disconnect()
except:
continue
led.off()
time.sleep(180)
except:
print('Catched Exception in main. Reset.')
machine.reset()
I think i found a bug. I have a poor connection on pins between esp and bme280, so when it import a library it cant found a bme, gives me error and crashes.
Should WDT works meanwhile or it crashes too?
can i use except on import?
import bme280_float
except:
print('Catched Exception in lib. Reset.')
machine.reset()
I'd fix the electrical connections first.
finally i catch an error:
so after this crash ESP dont work any more and turned off a led.
I wondering why WDT dont work and why my try/except dont catch that?
field1=58.55&field2=19.06
field1=60.30&field2=19.41
field1=59.20&field2=19.12
field1=58.71&field2=18.65
field1=57.84&field2=18.50
field1=59.69&field2=18.98
field1=60.58&field2=18.99
field1=58.97&field2=18.52
field1=58.40&field2=18.38
field1=60.12&field2=18.97
field1=60.62&field2=18.90
File "main.py", line 55, in <module>
File "umqtt/simple.py", line 97, in connect
IndexError: bytes index out of range
MicroPython v1.10-8-g8b7039d7d on 2019-01-26; ESP module with ESP8266
import bme280_float
import micropython
class WDT:
self._counter = 0
self.init()
def _wdt(self, t):
machine.reset()
def feed(self):
self._counter = 0
wdt=WDT()
WiFi_SSID = "ssid"
WiFi_PASS = "pass"
CHANNEL_ID = "77"
def do_connect():
wlan.active(True)
print
pass
def collectData():
#temp1 = result[0]
#hum1 = result[2]
led.on()
return temp1, hum1
ap_if.active(False)
wlan.active(True)
pass
print(payload)
client.connect()
client.disconnect()
except:
continue
led.off()
time.sleep(180)
except:
machine.reset()
The wdt should work. Are you waiting long enough? You have a timeout of 300s (5 minutes).
Kevin Köck
yes. i've check that receiving of data stops (widget on my android), come to ESP and see there is no led on. After that i go to sleep and come back at the morning, it was still off.
I just reset it and setted up an usb cable to see what happening.
That's strange. Can you check the wdt only to make sure it works? I'm using the same wdt code and it works all the time.
Kevin Köck
i've refactored code a little bit, and have started it to testing. It still working from yesterday.
Put connection to wifi and WDT to separate module. Maybe it make sense.
All exception works when i try to CTRL+C in REPL.
import bme280_float
import micropython
from wdt import WDT
import ConnectWiFi
ConnectWiFi.connect()
wdt = WDT(timeout=300)
CHANNEL_ID = "777"
WRITE_API_KEY = "XXX"
blue_led = Pin(2, Pin.OUT)
def collectData():
#temp1 = result[0]
#hum1 = result[2]
return temp1, hum1
i2c = machine.I2C(scl=machine.Pin(22), sda=machine.Pin(21))
print(payload)
client.connect()
client.disconnect()
except:
print("MQTT connect exception")
continue
for i in range(5):
time.sleep_ms(50)
blue_led.on()
time.sleep_ms(50)
blue_led.off()
time.sleep(180)
except:
machine.reset()
