As the comment in the code says it outputs meters.
You can use my library for comparison (you have to remove project specific imports and base class first though): https://github.com/kevinkk525/pysmartno ... /hcsr04.py
Module for Ultrasonic sensor (HC-SR04)
Re: Module for Ultrasonic sensor (HC-SR04)
Kevin Köck
Thank you for sharing the details Kevin. According to my knowledge i updated the code to read distance(removed mqtt, temperature code) and i am confused with below code. can you help me in modifying below code to read distance without temperature.kevinkk525 wrote: ↑Wed Jun 05, 2019 8:04 amAs the comment in the code says it outputs meters.
def _read(self):
Returns distance in cm.
Optionally compensated by temperature in °C.
:return: float
val = []
warnings = 0 # probably not going to happen that both warning types occur at the same time
warning = "minimum distance reached or different problem"
for _ in range(20):
pt = self._pulse()
if pt > 175: # ~3cm, sensor minimum distance, often read although other problems
val.append(pt)
warnings += 1
except OSError as e:
warning = e
warnings += 1
time.sleep_ms(10)
pt = 0
for i in range(len(val)):
pt += val[i]
pt /= len(val)
if temp is None:
dt = (pt / 2) / 29.14
dt = (pt / 2) * ((331.5 + (0.6 * temp)) / 10000)
if dt < 0:
await _log.asyncLog("warn", "Sensor reading <0")
return None
dt = round(dt, self._pr)
dt += self._off
except Exception as e:
await _log.asyncLog("error", "Error rounding value {!s}".format(dt))
return dt
Remove all the log instructions and add an optional parameter temp to the function like in my code. (temp=None)
It only corrects with a temperature if it gets one.
I'm currently not at home and only with my phone so can't give you a stripped down version.
Kevin Köck
async def _read(self) -> float:
:return: float
val = []
for _ in range(20):
pt = self._pulse()
val.append(pt)
warnings += 1
warning = e
warnings += 1
await asyncio.sleep_ms(10)
if warnings > 10: # half sensor readings are bad
print("error", "Too many bad sensor readings, error: {!s}".format(warning))
return None
# removing extreme values
val.remove(max(val))
val.remove(min(val))
pt = 0
pt += val[i]
pt /= len(val)
if temp is None:
if dt < 0:
print("warn", "Sensor reading <0")
return None
dt += self._off
print("error", "Error rounding value {!s}".format(dt))
return dt
return dt
Kevin Köck
Thank you Kevin. i will check and get back to you.kevinkk525 wrote: ↑Wed Jun 05, 2019 4:49 pmCode: Select all
async def _read(self) -> float: """ Returns distance in cm. Optionally compensated by temperature in °C. :return: float """ try: dt = round(dt, self._pr) dt += self._off except Exception as e: print("error", "Error rounding value {!s}".format(dt)) return dt return dt
RajaRamesh wrote: ↑Fri Jun 07, 2019 6:04 amHi Kevin, Now i can see the distance in cm. But, first it is display's error in rounding value. why is it happening?
dt += self._off
return dt
I guess self._pr isn't defined. you can replace it with 2
self._offs should be 0
Kevin Köck
Thank you Kevin for your help.kevinkk525 wrote: ↑Sat Jun 08, 2019 2:27 pmI guess self._pr isn't defined. you can replace it with 2
