Passing structs to external C modules
ProudPagan
Post by ProudPagan » Tue Jun 11, 2019 5:38 am
I need to pass a C struct (below) from MicroPython to an external C module.
typedef struct {
    struct myS *stptr;
    uint32_t i;
    uint32_t *jptr;
} myT;
I am planning to pack a ustruct and call the C function, but what `mp_obj_get_ ( )` should I call
in my C function to retrieve the struct?
Thanks very much!
PP
Re: Passing structs to external C modules
Post by jimmo » Tue Jun 11, 2019 8:33 am
If you're using ustruct.pack, you'll get a byte array (which is what I assume you're passing to your function). So your C function can get the underlying buffer and cast it to your struct type. Look at, for example, modframebuf.c for an example of something that takes a buffer from Python.
I'm not sure how you're going to use struct.pack to make the pointer members though?
ProudPagan
Post by ProudPagan » Wed Jun 12, 2019 7:59 am
Hi jimmo,
Thanks for the reply. You are right -- it might get very kludgy trying to use ustruct or uctypes, and probably
not possible at all.
Instead, I wrote a C wrapper around the lower level C functions. This C wrapper handles all the struct and
pointer management and will take a string and an integer (all operations are encoded in this string and will be parsed
by the C wrapper).
The MicroPython wrapper around my C wrapper will be like this:
STATIC mp_obj_t mp_my_c_wrapper (mp_obj_t oa, mp_obj_t oi) {
	const char *a = mp_obj_str_get_str(oa);
	int i = mp_obj_get_int(oi);
	char *val = malloc(2000);
        val = my_c_wrapper (a, i);
	return val; // FIXME: How do I return a string?
Two questions:
  • Is mp_obj_str_get_str() the right function to use to convert the mp_obj_t passed to mp_my_c_wrapper() to a char * ?
  • My C wrapper needs to return a string back to Python, How do I accomplish this?
Thanks!
Post by jimmo » Wed Jun 12, 2019 11:38 am
Yup, but you might be better off with mp_obj_str_get_data
See py/obj.h
qstr mp_obj_str_get_qstr(mp_obj_t self_in); // use this if you will anyway convert the string to a qstr
const char *mp_obj_str_get_str(mp_obj_t self_in); // use this only if you need the string to be null terminated
const char *mp_obj_str_get_data(mp_obj_t self_in, size_t *len);
mp_obj_t mp_obj_new_str(const char* data, size_t len);
ProudPagan
Post by ProudPagan » Thu Jun 13, 2019 3:52 am
Thanks a ton!
My module is now done.
PP
