however, this hasn't worked at all for me yet. The micropython side running the slave just keeps waiting. On the arduino blue pill side, all I see are send failures. I've tried to match up all the params of the radio based on the constructor code in micropython and ardunio.
Has anyone used arduino/micropython comms with NRF24L01+ successfully? If so, could you please post details of your setup and any obvious gotchas I might be missing. Code for both micropython and ardunio below.
ESP32 receiver:
"""Test for nrf24l01 module. Portable between MicroPython targets."""
import sys
import ustruct as struct
import utime
from machine import Pin, SPI, resetWDT
from nrf24l01 import NRF24L01
from micropython import const
# Slave pause between receiving data and checking for further packets.
_RX_POLL_DELAY = const(15)
# Slave pauses an additional _SLAVE_SEND_DELAY ms after receiving data and before
# transmitting to allow the (remote) master time to get into receive mode. The
# master may be a slow device. Value tested with Pyboard, ESP32 and ESP8266.
_SLAVE_SEND_DELAY = const(10)
if sys.platform == 'pyboard':
cfg = {'spi': 2, 'miso': 'Y7', 'mosi': 'Y8', 'sck': 'Y6', 'csn': 'Y5', 'ce': 'Y4'}
elif sys.platform == 'esp8266': # Hardware SPI
cfg = {'spi': 1, 'miso': 12, 'mosi': 13, 'sck': 14, 'csn': 4, 'ce': 5}
elif 'esp32' in sys.platform: # Software SPI
cfg = {'spi': 1, 'miso': 12, 'mosi': 13, 'sck': 14, 'csn': 15, 'ce': 27}
raise ValueError('Unsupported platform {}'.format(sys.platform))
pipes = (b'\xf0\xf0\xf0\xf0\xe1', b'\xf0\xf0\xf0\xf0\xd2')
nrf = None
def initspi():
global nrf
if nrf:
return
didInit = True
csn = Pin(cfg['csn'], mode=Pin.OUT, value=1)
ce = Pin(cfg['ce'], mode=Pin.OUT, value=0)
spi = SPI(cfg['spi'], sck=Pin(cfg['sck']),
mosi=Pin(cfg['mosi']), miso=Pin(cfg['miso']))
nrf = NRF24L01(spi, csn, ce, payload_size=8)
def master():
initspi()
nrf.open_tx_pipe(pipes[0])
nrf.open_rx_pipe(1, pipes[1])
nrf.start_listening()
num_needed = 16
num_successes = 0
num_failures = 0
led_state = 0
print('NRF24L01 master mode, sending %d packets...' % num_needed)
while num_successes < num_needed and num_failures < num_needed:
# stop listening and send packet
nrf.stop_listening()
millis = utime.ticks_ms()
led_state = max(1, (led_state << 1) & 0x0f)
print('sending:', millis, led_state)
nrf.send(struct.pack('i', millis))
except OSError:
pass
# start listening again
# wait for response, with 250ms timeout
start_time = utime.ticks_ms()
timeout = False
while not nrf.any() and not timeout:
if utime.ticks_diff(utime.ticks_ms(), start_time) > 250:
timeout = True
if timeout:
print('failed, response timed out')
num_failures += 1
# recv packet
got_millis, = struct.unpack('i', nrf.recv())
# print response and round-trip delay
print('got response:', got_millis, '(delay', utime.ticks_diff(utime.ticks_ms(), got_millis), 'ms)')
num_successes += 1
# delay then loop
utime.sleep_ms(250)
print('master finished sending; successes=%d, failures=%d' % (num_successes, num_failures))
nrf.powerDown()
def slave():
initspi()
nrf.open_tx_pipe(pipes[1])
nrf.open_rx_pipe(1, pipes[0])
print('NRF24L01 slave mode, waiting for packets... (ctrl-C to stop)')
resetWDT()
if nrf.any():
while nrf.any():
buf = nrf.recv()
millis = struct.unpack('i', buf)
led_state = 0
print('received:', millis, led_state)
for led in leds:
if led_state & 1:
led.on()
led.off()
led_state >>= 1
utime.sleep_ms(_RX_POLL_DELAY)
# Give master time to get into receive mode.
utime.sleep_ms(_SLAVE_SEND_DELAY)
except OSError:
pass
print('sent response')
leds = [pyb.LED(i + 1) for i in range(4)]
except:
leds = []
print('NRF24L01 test module loaded')
print('NRF24L01 pinout for test:')
print(' CE on', cfg['ce'])
print(' CSN on', cfg['csn'])
print(' SCK on', cfg['sck'])
print(' MISO on', cfg['miso'])
print(' MOSI on', cfg['mosi'])
print('run nrf24l01test.slave() on slave, then nrf24l01test.master() on master')
Blue pill sender (arduino)
#include "WProgram.h"
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <stdio.h>
// Hardware configuration
#define PIN_START PB9
int CE_PIN = PB0;
int CSN_PIN = PA4;
// SPI Class for communication with SPI
SPIClass SPI_1(1);
RF24 radio(SPI_1, CE_PIN, CSN_PIN);
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = {0xF0F0F0F0E1, 0xF0F0F0F0D2};
void setup(void)
delay(5000);
Serial.begin(9600);
pinMode(LED_BUILTIN, OUTPUT);
SPI_1.begin();
SPI_1.setDataMode(SPI_MODE0);
SPI_1.setBitOrder(MSBFIRST);
pinMode(PIN_START, INPUT_PULLDOWN);
delay(5);
while (!digitalRead(PIN_START))
Serial.println("Pull pin PB9 high to start");
delay(1000);
radio.begin();
radio.setChannel(46);
radio.setDataRate(RF24_250KBPS);
radio.setPALevel(RF24_PA_MAX);
radio.setRetries(6, 8);
radio.setPayloadSize(8);
radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1, pipes[1]);
radio.startListening();
// Dump the configuration of the rf unit for debugging
radio.printDetails();
void toggleLED()
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
void loop(void)
toggleLED();
// First, stop listening so we can talk.
radio.stopListening();
// Take the time, and send it. This will block until complete
unsigned long time = millis();
printf_P("Now sending %lu...", time);
bool ok = radio.write(&time, sizeof(unsigned long));
if (ok)
Serial.println("ok...\r\n");
else
Serial.println("failed.\r\n");
// Now, continue listening
// Wait here until we get a response, or timeout (250ms)
unsigned long started_waiting_at = millis();
bool timeout = false;
while (!radio.available() && !timeout)
if (millis() - started_waiting_at > 200)
timeout = true;
// Describe the results
if (timeout)
Serial.println("Failed, response timed out.\r\n");
else
// Grab the response, compare, and send to debugging spew
unsigned long got_time;
radio.read(&got_time, sizeof(unsigned long));
// Spew it
printf_P("Got response %lu, round-trip delay: %lu\r\n", got_time, millis() - got_time);
toggleLED();
// Try again 1s later
delay(1000);
