MicroPython minimal port on NUCLEO F446ZE
ferran.campos
Post by ferran.campos » Tue Jul 23, 2019 4:54 pm
I'm trying to execute the minimal port of micropython on the NUCLEO - F446ZE. As the README file says, it should work on STM32 F4 series. However, that's not the case. The code is actually writen succesfully on the board through ST-LINK and the Micropython initializes as expected showing the following: 'MicroPython v1.11 on 2019-07-23; minimal with unknown-cpu'.
The problem occurs when trying to write any line of code. It doesn't matter if it's a variable definition or a print, micropython crashes showing nothing on the console.
Has anyone been through the same or any ideas on how to solve this?
Thanks.
Re: MicroPython minimal port on NUCLEO F446ZE
Post by dhylands » Tue Jul 23, 2019 9:04 pm
Do you have an up-to-date micropython tree?
There was an issue which was fixed about 3 weeks ago. I get the following on my NUCLEO_F446RE:
MicroPython v1.11-167-g331c224e0-dirty on 2019-07-23; minimal with unknown-cpu
>>> print('Hey there')
Hey there
>>> x = 3
>>> print(x)
3
ferran.campos
Post by ferran.campos » Wed Jul 24, 2019 8:09 am
That was it, I had a version from a month ago. With the updated one works perfectly. Thank you!
safetyfactorman
Post by safetyfactorman » Tue Aug 06, 2019 11:01 pm
I was wondering how to configure or setup (jumper pins?) the board so that it can be flashed. I have looked on the stm site for information on how to to do that, but it is unclear to me.
Maybe a general note on how to set stm32 boards, if such is possible, would be greatly appreciated by many, I am sure.
thanks,
Mark
Post by jimmo » Tue Aug 06, 2019 11:37 pm
You'll need to short the BOOT0 pin to VCC then reset. That will put the board into the ST DFU bootloader so you can use "make BOARD= deploy" via the device usb port.
Otherwise you can use the stlink usb port any time with "make BOArD= deploy-stlink"
safetyfactorman
Post by safetyfactorman » Wed Aug 07, 2019 3:16 pm
Thanks!
ketkipatil
Post by ketkipatil » Thu Aug 08, 2019 7:14 am
Well explained...
