Booting normal or serial/usb
McDiver
Post by McDiver » Fri Aug 09, 2019 11:22 am
Hi
In my code i need to check if the module booted in normal mode or with usb/serial connected.
How can i check that ?
Tommy
Re: Booting normal or serial/usb
Post by Roberthh » Fri Aug 09, 2019 11:42 am
Which board are you using? On STM32 board, you can check whether USB is connected e.g. with pyb.USB_VCP.isconnected() (http://docs.micropython.org/en/latest/l ... sconnected).
On ESP32 and ESP8266 this is not possible, since the connect through UART.
