Hello all,
I have been facing errors trying to build for a custom board(VCB_OR). Keep getting this error (attaching a snippet towards the end):
compilation terminated.
network_lan.c:34:24: fatal error: lwip/netif.h: No such file or directory
#include "lwip/netif.h"
modnetwork.c:43:24: fatal error: lwip/netif.h: No such file or directory
In file included from ../../lib/netutils/dhcpserver.c:38:0:
../../lib/netutils/dhcpserver.h:29:26: fatal error: lwip/ip_addr.h: No such file or directory
#include "lwip/ip_addr.h"
../../py/mkrules.mk:74: recipe for target 'build-VCB_OR/genhdr/qstr.i.last' failed
make: *** [build-VCB_OR/genhdr/qstr.i.last] Error 1
make: *** Deleting file 'build-VCB_OR/genhdr/qstr.i.last'
It seems to be some sort of cross compiling issue or dependency issue but I am unsure how to fix it.
Any help would be appreciated.
Errors when trying to build
Re: Errors when trying to build
Did you run:
git submodule update --init
after cloning?
after cloning?
Yes, I did
When I tried building for a different board just to test it built fine.
So not too sure what could be causing the error
You need to make sure you have this line:
https://github.com/micropython/micropyt ... ard.mk#L10 (i.e. MICROPY_PY_LWIP = 1) in your mpconfigboard.mk file
Thanks for that. It seems to have solved that issue.
I also had to remove this line from mpconfigboard.h :
#define MICROPY_PY_LWIP (1)
But now the build is failing at eth.c file with the following error:
CC eth.c
eth.c: In function 'eth_mac_init':
eth.c:163:5: error: implicit declaration of function 'STATIC_AF_ETH_RMII_REF_CLK' [-Werror=implicit-function-declaration]
mp_hal_pin_config_alt_static(MICROPY_HW_ETH_RMII_REF_CLK, MP_HAL_PIN_MODE_ALT, MP_HAL_PIN_PULL_NONE, STATIC_AF_ETH_RMII_REF_CLK);
cc1: all warnings being treated as errors
../../py/mkrules.mk:47: recipe for target 'build-VCB_OR/eth.o' failed
make: *** [build-VCB_OR/eth.o] Error 1
I'm not entirely sure the cause this time. I understand it's only a warning but the gcc compiler won't allow it to continue
CC eth.c
