Adafruit Feather Huzzah esp8266 not running MicroPython
I am trying to put the MicroPython firmware on my new feather Huzzah and I can flash the firmware fine and it seems to be successful but when I go to start the REPL in PuTTY I am getting a weird flashing line. I have attached some screenshots from flashing, PuTTY configs. and PuTTY console. I was able to flash it with CircuitPython and it worked fine but for some reason MicroPython is not working.
- PuTTY console screen (Its flashing that one line very fast)
- PuTY_Cons.PNG (6.22 KiB) Viewed 5275 times
- PuTTY configs
- PuTTY_sesh.PNG (32.5 KiB) Viewed 5275 times
- command console after firmware flash
- command_Cons.PNG (44.77 KiB) Viewed 5275 times
Re: Adafruit Feather Huzzah esp8266 not running MicroPython
The speed in your putty config looks correct, but every time I've seen the writings of Cthulhu in a terminal when attempting a serial connection it was because I had the speed wrong.
Probably not the reason, but have you tried using the latest version, v1.11?
If you press enter a few times at the terminal, does the prompt appear?
Yeah, I've tried both versions and tried enter a few times in the console. Nothing seems to respond in the PuTTY console.
And you've tries ctrl-c also?
Hrmm... I wonder... did you do an erase_flash before programming? Might be worth trying?
I guess I didn't try ctl-c. I'll have to try that later (I'm at work now haha). I did erase the flash and re-flashed multiple times.
Did you switch flow control in Putty off?
I have not messed with the flow control at all. currently it is set to XON/XOFF. Are you saying maybe I should try no flow control? I'm not sure what RTS/CTS or DSR/DTR actually are.
Set it to no glow control.
That did it for me. Thank you!
