Network LAN
kcoelho
Network LAN
Post by kcoelho » Mon Aug 19, 2019 2:07 pm
Where can I find more information / documentation about the network.LAN functionality?
Trying to use it for a project but cannot seem to find anything
Thank you
Re: Network LAN
Post by pythoncoder » Mon Aug 19, 2019 5:34 pm
What hardware are you using?
kcoelho
Re: Network LAN
Post by kcoelho » Mon Aug 19, 2019 6:11 pm
It's a custom board but very similar to the Olimex - e407.
Additionally, after adjusting some drivers to enable this, my ADC keeps spitting out 0 values. It used to be working perfectly before
kcoelho
Re: Network LAN
Post by kcoelho » Wed Aug 21, 2019 9:21 pm
I am still having trouble with this. Is there anywhere I could be referred to for assistance?
Re: Network LAN
Post by pythoncoder » Thu Aug 22, 2019 6:29 am
I assume you've seen the official docs. Implementation of the network module is port specific: look in the source tree for modnetwork.c.
kcoelho
Re: Network LAN
Post by kcoelho » Thu Aug 22, 2019 1:03 pm
Thanks,
I think I understand your point. While I can import the network and usocket modules in REPL, I do not have access to the AbstractNIC class and the socket connections do not appear to be working.
So would that mean I have to write my own custom driver for the board?
Re: Network LAN
Post by pythoncoder » Fri Aug 23, 2019 5:55 am
This is way outside of my experience. My general approach would be:
  • Determine the chip used for the Ethernet adaptor.
  • Search high and low for a C driver for it with source code.
  • Assuming you find one, learn how the author integrates the low level driver into the network stack.
  • See how existing network adaptors (e.g. WiFi, CC3200) integrate into MicroPython.
  • Roll your sleeves up and set to work.
Not for the faint hearted and not one for me.
rpr
Re: Network LAN
Post by rpr » Fri Aug 23, 2019 3:31 pm
If the board uses a lan8720 chipset, the loboris fork for the esp32 has support in micropython. Loboris made some small hardware mods to the lan8720 boards he was using. There is at least a thread on his forum.
https://loboris.eu/forum/showthread.php?tid=334
Loboris commented that he thought his code should work for the olimex boards.
kcoelho
Re: Network LAN
Post by kcoelho » Fri Aug 23, 2019 8:23 pm
Hi rpr,
It uses a LAN8710 chipset, which should be quite similar.
I'll take a look into that and let you know the outcome.
Thank you
rpr
Re: Network LAN
Post by rpr » Sat Aug 24, 2019 12:15 am
Hi rpr,
Thank you
Thanks. I'm interested.
