Urequests problem (multiple Post) with google docs/forms
Sorry guys, I'm a begginer in micropython, I wanted to know if it could be possible to convert this arduino code to micropython. This code is for posting data in google spreadsheets without using IFTTT (it requieres a public google script). I've taken it from a youtube example (https://www.youtube.com/watch?v=Fq1kgt_auns).
I'm not using the MLX90614, i have an analog sensor. I mean, i'm only interested on the communication part of the code. But i don't know if it could be possible to do http request directly with a public script using micropython. As a test i'd like to send a couple of integers...
Github repository:
https://github.com/embhobbb/esp8266/tre ... oogleSheet
Arduino code:
#include <ESP8266WiFi.h>
#include "HTTPSRedirect.h"
#include <Wire.h>
#include <Adafruit_MLX90614.h>
// Fill ssid and password with your network credentials
const char* ssid = "hidden";
const char* password = "qwerty12";
const char* host = "script.google.com";
const int httpsPort = 443;
const char *GScriptId = "AKfycbwhcnmC6cSE_P5MKice-T6GX8pfe4rFFNiKUnY9-vuwE9hwzCA";
// Write to Google Spreadsheet
String url = String("/macros/s/") + GScriptId + "/exec?tag=adc_A0&value=";
String payload = "";
HTTPSRedirect* client = nullptr;
// used to store the values of free stack and heap
// before the HTTPSRedirect object is instantiated
// so that they can be written to Google sheets
// upon instantiation
const int analog_ip = A0;
int inputVal = 0;
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
void setup() {
Serial.begin(115200);
Serial.flush();
Serial.println();
Serial.print("Connecting to wifi: ");
Serial.println(ssid);
Wire.begin(D1,D2);
// flush() is needed to print the above (connecting...) message reliably,
// in case the wireless connection doesn't go through
Serial.flush();
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
// Use HTTPSRedirect class to create a new TLS connection
client = new HTTPSRedirect(httpsPort);
client->setPrintResponseBody(true);
client->setContentTypeHeader("application/json");
Serial.print("Connecting to ");
Serial.println(host);
// Try to connect for a maximum of 5 times
bool flag = false;
for (int i=0; i<5; i++){
int retval = client->connect(host, httpsPort);
if (retval == 1) {
flag = true;
break;
else
Serial.println("Connection failed. Retrying...");
if (!flag){
Serial.print("Could not connect to server: ");
Serial.println("Exiting...");
return;
payload = "tag=aaaa&value=122";
client->POST(url, host, payload, false);
client->GET(url, host);
void loop() {
static int connect_count = 0;
static bool flag = false;
Serial.print("Ambient = ");
inputVal = mlx.readObjectTempC();
Serial.print(inputVal);
Serial.println("*C");
String myString = String(inputVal);
String FinalStringToSend;
FinalStringToSend = url + myString;
if (client != nullptr){
if (!client->connected()){
payload= "";
Serial.println("POST Data to Sheet");
// FinalStringToSend = url + myString;
Serial.println("POST url :" + FinalStringToSend);
client->POST(FinalStringToSend, host, payload);
else{
Serial.println(" >> Failed to POST data");
Serial.println("GET url :"+FinalStringToSend);
client->GET(FinalStringToSend, host);
delay(500);
I've already used IFTTT but at this point is not usefull for me, i need a sampling rate of more or equal to 100 Hz and as you know this exceeds the IFTTT's usage limit. I've tried making a RAM buffer, but i got a error saying that the buffer exceded the RAM size . As i told you, it could be possible to convert this code or do you have any suggestion of what could i do? Thank you
Github repository:
Arduino code:
#include <Wire.h>
int inputVal = 0;
void setup() {
Serial.flush();
Serial.println();
Wire.begin(D1,D2);
Serial.flush();
delay(500);
Serial.print(".");
Serial.println("");
bool flag = false;
if (retval == 1) {
flag = true;
break;
else
if (!flag){
return;
void loop() {
payload= "";
else{
delay(500);
Last edited by MoustachedBird on Sat Sep 14, 2019 4:02 am, edited 6 times in total.
Re: Convert arduino code to esp8266 micropython (google sheets) or suggestion
Converting Arduino code to MicroPython is not particularly difficult but you do need a reasonable knowledge of C/C++ and Python. The Adafruit way of accessing hardware is somewhat different but there is a driver for the MLX90614 so using that should be easy.
Sorry, i forgot to say that i'm not using the MLX90614, i have an analog sensor. I mean, i'm only interested on the communication part of the code. But i don't know if it could be possible to do http request directly with a public script using micropython.
Re: Convert arduino code to esp8266 micropython (google sheets without IFTTT) or suggestion
You might find some of the posts in this thread useful -- viewtopic.php?f=18&t=6492 -- I was able to make some values appear in a spreadsheet using a form submission.
Thank you for your time. Sorry, what do you mean with 'application/x-www-form-urlencoded'jimmo wrote: ↑Mon Sep 09, 2019 9:17 amHi,
>>> import urequests
>>> h = {'Content-Type': 'application/x-www-form-urlencoded' }
>>> form_url = 'https://docs.google.com/forms/d/e/<doc id>/formResponse'
>>> form_data = 'entry.714340709=micropython'
>>> r = urequests.post(form_url, data=form_data, headers=h)
>>> r.status_code
200
When you post data over HTTP you have a few options how to encode the data. urlencoded and json are two very common options. the example arduino code you posted actually uses urlencoded despite saying json.MoustachedBird wrote: ↑Mon Sep 09, 2019 8:39 pmThank you for your time. Sorry, what do you mean with 'application/x-www-form-urlencoded'
Thank you so much, it works!!! But I have a last question, if i wanted to post data to more than one entry what would be neccesary to do? I've tried with this:
url = 'https://docs.google.com/forms/d/<MY_ID>/formResponse'
form_data = {'entry.61639300=1','entry.1495906291=2','entry.211888248=3'}
#user_agent = {'Content-Type': 'application/x-www-form-urlencoded'}
r = urequests.post(url, data=form_data, headers=user_agent)
But i've got this error:
TypeError: object with buffer protocol required
Also i've tried using useragent = {'Content-Type': 'application/json'} but i've got the same error.
The syntax
causes form_data to be an instance of a Python set. It should be a string, as per your earlier example.
Thank you for your response. Sorry, i dont want to bother you , but now i want to do multiple post-requests, so i have edited the code, but i've got this error.pythoncoder wrote: ↑Tue Sep 10, 2019 6:00 amThe syntaxcauses form_data to be an instance of a Python set. It should be a string, as per your earlier example.Code: Select all
The code:
url = 'my_url'
form_data = 'my.entry=my_data'
response = urequests.post(url, data=form_data, headers=user_agent)
print("CONTENT:")
print(response.json)
print("WAITING...")
time.sleep_ms(500)
print("TRYING TO SEND...")
Again, i don't know if this is possible or maybe i have to increase the sleep time; when i increase it to 10 minutes it works, but for me it is too slow because of the sample rate. I don't get why the sleep time would be a problem since Google does receive the firts data and i would like to think that after that the esp8266 is free to send other. Thank you guys.CONTENT:
<bound_method>
WAITING...
TRYING TO SEND...
File "main.py", line 50, in <module>
File "main.py", line 42, in main
File "urequests.py", line 115, in post
File "urequests.py", line 53, in request
OSError: -2
Is it possible that Google impose some form of throttling?
