New version of Thonny IDE
aivarannamaa
Post by aivarannamaa » Mon Nov 04, 2019 2:03 pm
Hi everybody!
I just released a new version of Thonny IDE with several improvements related to MicroPython: https://github.com/thonny/thonny/releases/tag/v3.2.3
Usage instructions are here: https://github.com/thonny/thonny/wiki/MicroPython
Looking forward to your feedback!
Best regards
Aivar
Aivar Annamaa
https://thonny.org
pidou46
Re: New version of Thonny IDE
Post by pidou46 » Tue Nov 05, 2019 7:41 am
Nice!
It's my prefered option to work with micropython powered MCU (ESP8266 ad ESP32)
It make the process of writing code for micropython alot easier thant everything I have tried before.
nodemcu V2 (amica)
pidou46
Post by pidou46 » Thu Nov 07, 2019 9:28 pm
This latest release bring studding stability, it works flawlessly for all my uses cases.
kudos to Aivar :D
nodemcu V2 (amica)
net0040
Post by net0040 » Fri Nov 08, 2019 6:11 am
Hi everybody!
Best regards
Aivar
Great, thank you for your work, I used to debug micropython with other Ide Tool, Try Thonny IDE now. :D
chrismas9
Post by chrismas9 » Fri Nov 15, 2019 2:46 am
What i still miss: automatic sync files on device <-> local
I actually use Thonny to avoid writing to local flash. I have multiple test scripts with different names that Thonny lets me run in RAM without renaming them to main.py. Only when one is tested do I download it as main.py. Also some of my small targets (256k) don't have a filesystem so I use Thonny to test them before freezing.
Thanks for developing and maintaining Thonny.
jedie
Post by jedie » Fri Nov 15, 2019 7:37 am
Yes, Thonny is great. It's a good place for experimenting. But it is difficult to keep your sources up to date in the local git, because thonny doesn't save the sources locally at the same time.
For this, i created: https://github.com/thonny/thonny/issues/990
jedie
Post by jedie » Fri Dec 27, 2019 1:01 pm
Wow, cool. New Thonny version (3.2.5) keeps the device connection even after a heard reset. This is really very helpful!
