On both builds I first connect to my wifi then try to use upip.
I was trying to upip install urequests using
upip.install("micropython-urequests")
On the IDF4 based builds it throws an error.
I already asked in IRC but I figured it would be best to also post here for anyone else running into this problem.>>> upip.install("micropython-urequests")
Installing to: /lib/
Error installing 'micropython-urequests': [Errno 12] ENOMEM, packages may be partially installed
