A power meter - using the Pyboard as a measuring instrument
Re: A power meter - using the Pyboard as a measuring instrument
Post by pythoncoder » Fri Nov 22, 2019 11:03 am
In paragraph 2 you will find a description of that project and a link to its docs at the bottom.
It was largely superseded by the advent of the Pyboard D which is a greatly superior solution.
ta1db
Post by ta1db » Fri Nov 22, 2019 7:11 pm
Oh, how come! I just realized that it is fully documented here https://github.com/peterhinch/micropyth ... /NO_NET.md starting from 2nd paragraph as you've said. :oops:
Thank you Peter, I will study your method :idea:
