a = object_a_that_allocates()
a = object_b_that_allocates()
As an aside I have found that periodically performing explicit calls to gc.collect() reduces fragmentation.
It doesn't do this by itself. On an esp8266 with initially 32k of free RAM the following test fails as expected on the second assignment to "b":pythoncoder wrote: ↑Sat Dec 21, 2019 6:39 am@jimmo I find that last example surprising, please could you explain? If I writeby line 2 the instance of object_a_that_allocates has no references to it. Why won't the GC free its RAM? How does assigning None change this?Code: Select all
a = object_a_that_allocates() a = object_b_that_allocates()
import gc
gc.collect()
print(gc.mem_free())
a = []
for i in range(1, 31):
a.append('x' * 1000)
b = 'x' * 1000
b = 'y' * 1000
for string in list_object:
a=do_something(string)
send_string(a)
a=None
gc.collect()
a = ...something that allocates...
gc.collect()
a = ...something else that allocates...
a = None
gc.collect()
MicroPython v1.12 on 2019-12-20; ESP module with ESP8266
>>> import gc
>>> gc.threshold()
9488
In this case i would do this:kevinkk525 wrote: ↑Sun Dec 22, 2019 7:26 amCode: Select all
for string in list_object: a=do_something(string) send_string(a) a=None gc.collect()
send_string(do_something(string))
gc.collect()
def foo():
a = do_something(string)
send_string(a)
foo()
gc.collect() # 'a' should be cleared, isn't it?
a = foo()
a = bar()
a = None
Yep, exactly what dhylands said. Until `a` is assigned the second time (which happens _after_ the new allocation), the reference to the old data is still live, so cannot be freed.pythoncoder wrote: ↑Sun Dec 22, 2019 6:54 amWhat baffles me is the assertion from @jimmo that assigning None has any effect on behaviour: if this is true I'd like to know the reason.
When the allocator fails to allocate, it always runs a gc.collect first then tries again before actually failing the allocation.MostlyHarmless wrote: ↑Sat Dec 21, 2019 2:43 pmAssigning None and calling gc.collect() does. This means that an out of memory doesn't try running gc.collect() by itself.
>>> import gc, micropython
>>> micropython.mem_info()
mem: total=5528, current=1582, peak=3161
stack: 960 out of 80000
GC: total: 16128, used: 2752, free: 13376
No. of 1-blocks: 54, 2-blocks: 11, max blk sz: 6, max free sz: 413
>>> a = bytearray(10*1024)
MemoryError: memory allocation failed, allocating 10240 bytes
>>> a = None
>>> a = bytearray(10*1024) # This works
Yes, this is exactly the scenario where assigning to None will help.kevinkk525 wrote: ↑Sun Dec 22, 2019 7:26 amThe only situation where I assign None is in a loop:
Here it makes sense so the temporary veriable a gets collected after each iteration.
Yes, this is another way of achieving the same thing. When a function returns it's local variables are now out of scope and will not be found by the gc.
some_program_state = something()
def update():
global some_program_state
some_program_state = maybe_get_new_program_state()
except:
pass
Yes -- frequent gc.collect() will help with fragmentation. I'm not sure I have a good way to put this into words without a diagram but essentially if you can synchronise your collections with your program "loop", then you'll end up playing out the same allocation pattern across RAM every time.pythoncoder wrote: ↑Sat Dec 21, 2019 6:39 amAs an aside I have found that periodically performing explicit calls to gc.collect() reduces fragmentation.
This is related to the above. It changes the code that I described above where it will do a gc.collect() if it fails to find enough free heap, into preemptively collecting if the available heap drops below a threshold.
