tl;dr For serious reliability the Pyboard D seems to be the best platform for WiFi applications.
Using the asynchronous resilient MQTT mqtt_as.py in this repo I am running long term tests. To date these have accumulated 30 days running in one location with RSSI -56dB and 14 days in another with RSSI -83dB - in our garden shed far from the AP.
These tests are still running without failure. There is no watchdog timer in use.
The test script exchanges messages every 5s with qos==1. The library performs re-publications in the event of WiFi disruption and recovers from WiFi outages with no qos==1 data loss. The test script reports outages as seen by the Pyboard and also maintains and reports the repub count.
At the -56dB location in 30 days two outages occurred with four repubs - in over 500K publications. At the -83dB location in 14 days it saw one outage and 21 repubs.
I have no comparable quantitative data for ESP8266 or ESP32 but I have done a good deal of testing with them. The ESP8266 in particular experiences outages much more frequently. I believe it occasionally crashes, necessitating a WDT, but intend to re-test to confirm this.
If anyone wishes to replicate these tests it is vital to have a high quality power supply. Some USB wall-warts are poor and cause crashes on any platform.
Reliability test results: Pyboard D and MQTT
Re: Reliability test results: Pyboard D and MQTT
That sounds promising. -83dBm is a quite weak signal.
Thanks for all your testing efforts and patience!
Kevin Köck
Is your code available somewhere? I'd be interested in testing using an esp32...
The resilient MQTT repo is here. It has been tested on ESP32 for resilience, but the long term tests have so far included only Pyboard D and ESP8266.
I'm aware of the repo, but when you write "The test script exchanges messages every 5s with qos==1" which script do you specifically run?
I run this one on the unit under test. The mosquitto broker runs on a Raspberry Pi, and I run mosquitto_sub on the Pi to display the results. Another terminal on the Pi runs this script to provide messages for the unit's subscription.
The Pi is just a Linux box which is economical to run 24/7 - any networked Linux box will do.
