I am using Wemos D1 mini pro with latest MP flashed to it and have been playing around with different examples and am really enjoying tinkering again as python makes it alot easier then using C/C++.
I wanted to try out the blynk library from the offical repo, however as soon as I import it I get a memory error :/
# main.py
from libs import blynklib_mp as BlynkLib
# serial
MemoryError: memory allocation failed, allocating 138 bytes
I have had more item imported than this at once such as mqtt, weather api, dictionary parser and it hasn't been an issue.
Is there something I can do other than compile the library into the framework?
Thanks.
