BUG in activating network interfaces
jomas
Post by jomas » Sat Jan 11, 2020 2:42 pm
I think there is a bug in activating sta/ap interfaces.
When running the script below, ap_if.active() wil continuously print False.
However the bug will only appear with sta_if configured with SSID and pasword for your modem/router and with ap_active deactivated on start of the script.
If ap_if.active() returns True, then run ap_if.activate(False) and run the script again. After a few runs the bug will appear.
If I use the time.sleep(0.1) then everything works as expected.
Can someone confirm this bug? (I used the latest 1.12 version from the main Python site)
ap_if = network.WLAN(network.AP_IF)
ap_if.active(True)
# time.sleep(0.1)
sta_if.active(True)
    print("AP: ", ap_if.active())
    print("STA: ", sta_if.active())
    if ap_if.active():
        if sta_if.active():
            print("All interfaces active")
            break
    time.sleep(1)
