NRF - PR5472 Build Sanity Check Please ?
devnull
Post by devnull » Sun Jan 12, 2020 11:15 am
Hello All;
Would really appreciate if someone else can verify that the errors I am getting during build for the NRF with FAT enabled on the PCA10056 development board can be replicated by someone else, as this is driving me nuts !.
See the threads here: https://github.com/micropython/micropyt ... -573270500
Here's the method I used to build:
1) Pull in PR 5472 that enables FAT support
# cd /nfs/qnap/dev/uPython/build/micropython/micropython
# git fetch origin pull/5472/head:PR-5472
remote: Enumerating objects: 17, done.
remote: Counting objects: 100% (17/17), done.
remote: Total 20 (delta 17), reused 17 (delta 17), pack-reused 3
Unpacking objects: 100% (20/20), done.
From https://github.com/micropython/micropython
 * [new ref]             refs/pull/5472/head -> PR-5472
# git checkout PR-5472
Switched to branch 'PR-5472'
2) Install Bluetooth soft-device
cd /nfs/qnap/dev/uPython/build/micropython/micropython/ports/nrf/drivers/bluetooth
./download_ble_stack.sh
3) Enable FAT support during MAKE:
make -j8 BOARD=pca10056 SD=s140 MICROPY_VFS_VFAT=1
4) Build Fails:
mkdir -p build-pca10056-s140/genhdr
mkdir -p build-pca10056-s140/device/
mkdir -p build-pca10056-s140/drivers/
mkdir -p build-pca10056-s140/drivers/bluetooth/
CC ../../lib/utils/interrupt_char.c
CC ../../lib/timeutils/timeutils.c
CC build-pca10056-s140/pins_gen.c
LINK build-pca10056-s140/firmware.elf
/usr/lib/gcc/arm-none-eabi/7.3.1/../../../arm-none-eabi/bin/ld: /tmp/ccaI98Ul.ltrans3.ltrans.o: in function `factory_reset_filesystem':
/nfs/qnap/dev/uPython/build/micropython/micropython/ports/nrf/main.c:134: undefined reference to `f_mkfs'
/usr/lib/gcc/arm-none-eabi/7.3.1/../../../arm-none-eabi/bin/ld: /nfs/qnap/dev/uPython/build/micropython/micropython/ports/nrf/main.c:141: undefined reference to `f_setlabel'
/usr/lib/gcc/arm-none-eabi/7.3.1/../../../arm-none-eabi/bin/ld: /nfs/qnap/dev/uPython/build/micropython/micropython/ports/nrf/main.c:142: undefined reference to `mp_fat_vfs_type'
/usr/lib/gcc/arm-none-eabi/7.3.1/../../../arm-none-eabi/bin/ld: /tmp/ccaI98Ul.ltrans1.ltrans.o:(.rodata+0x1298): undefined reference to `mp_fat_vfs_type'
/usr/lib/gcc/arm-none-eabi/7.3.1/../../../arm-none-eabi/bin/ld: /tmp/ccaI98Ul.ltrans4.ltrans.o: in function `os_sync.lto_priv.510':
/nfs/qnap/dev/uPython/build/micropython/micropython/ports/nrf/modules/uos/moduos.c:92: undefined reference to `disk_ioctl'
collect2: error: ld returned 1 exit status
make: *** [Makefile:426: build-pca10056-s140/firmware.elf] Error 1
Re: NRF - PR5472 Build Sanity Check Please ?
Post by jimmo » Sun Jan 12, 2020 1:04 pm
I'll try and repro your steps during the week, but shouldn't it be MICROPY_VFS_FAT? (not VFAT)
devnull
Post by devnull » Mon Jan 13, 2020 1:54 am
@jimmo - thanks, well spotted - that was the cause of the problem,
MICROPY_VFS_VFAT
should be
MICROPY_VFS_FAT
After that it builds
:oops:
