mydata.proto
syntax = "proto2";
package tutorial;
message Data {
required string id = 1;
required string type = 2;
repeated float values1 = 3;
repeated int32 values2 = 4;
import os
os.environ['MSGPACK_PUREPYTHON'] = '1'
import mydata_pb2
import msgpack
import cProfile
import json
# Replicate class we use with protobuf.
class Data:
def __init__(self, **kwargs):
self.id = kwargs.get('id', '')
self.type = kwargs.get('type', '')
self.values1 = kwargs.get('values1', [])
self.values2 = kwargs.get('values2', [])
def PopulateData(d):
d.id = 'foo'
d.type = 'bar'
d.values1.extend([float(x) for x in range(1000)])
d.values2.extend([x for x in range(1000)])
return d
rawData = PopulateData(Data())
protoData = PopulateData(mydata_pb2.Data())
iters = 1000
def RunProtoBuf():
for _ in range(iters):
mydata_pb2.Data().ParseFromString(protoData.SerializeToString())
def RunMessagePack():
Data(**msgpack.unpackb(msgpack.packb(rawData.__dict__), raw=False))
def RunJSon():
Data(**json.loads(json.dumps(rawData.__dict__)))
cProfile.run('RunProtoBuf()')
cProfile.run('RunMessagePack()')
cProfile.run('RunJSon()')
32723695 function calls (32723688 primitive calls) in 16.911 seconds
29686004 function calls (25670004 primitive calls) in 14.861 seconds
21004 function calls in 0.806 seconds
