Hello to everyone
i have a problem with this program regarding the mqtt in fact it gives me this error message: ImportError: no module named 'umqtt' i don't know how to solve
thank you
P.S. forgive english but it is not my language
this is the program
import dht
SSID = "NETGEAR84"
PASSWD = ""
def do_connect():
if not sta_if.isconnected():
print("connecting to network.....")
sta_if.active(True)
sta_if.connect(SSID, PASSWD)
pass
print("network config:",sta_if.ifconfig())
do_connect()
SERVER = "192.168.1."
CLIENT_ID = "ESP8266"
TOPIC = "t_h"
client = MQTTClient(CLIENT_ID,SERVER)
client.connect()
d = dht.DHT22(machine.Pin(14))
d.measure()
t = d.temperature()
h = d.humidity()
msg = str(t) + "," + str(h)
client.publish(TOPIC,msg)
print(msg)
except OSError:
print("errore")
time.sleep(4)
problem with mqtt
Re: problem with mqtt
These files arfe not always included in the build. You can find them in the micropython-lib:
https://github.com/micropython/micropyt ... /robust.py
https://github.com/micropython/micropyt ... /simple.py
You have to create a directory name umqtt on you board and copy these files to that directory. I do not know, which board you are using, so the method for copying varies.
you also need to create a __init__.py in that umqtt folder (an empty file).
Kevin Köck
I created the mqtt folder inside the esp8266 in the folder I inserted the empty __init__.py file but after doing this it is as if the card had stopped working to connect to the card I use the picocom command from the mac terminal but doing so now gives me terminal ready but no I can write nothing and if I press the reset button on the board it does not reset correctly because it no longer executes the two files boot.py and main.py if I did it before the creation of __init__.py everything worked correctly I already tried to clear the memory of the card and reinstall micropython but nothing has changed what could have happened?
