Using the make command we are able to create a .hex file but how can we create a .dfu file?
Can you please explain?
How to create a DFU file on our own?
Re: How to create a DFU file on our own?
If you run make with V=1 then it will show you the commands it uses to create the .dfu file.
For the ports that support it (i.e. that have a dfu target)
Which port are you using?
Look at ports/stm32/Makefile which has a .dfu target if you need to copy this to another port.
make build-BOARD/firmware.dfu
Thank you for the replies guys!
We were able to build the DFU file.
