How to get BLE beacons
One ESP32 board is advertising BLE beacons. I want to scan thees beacons on another ESP32 board. How can I do it?
Re: How to get BLE beacons
A BLE beacon just includes its data in the advertising payload. So you'll see this when you scan for devices (i.e. ble.gap_scan() ).
See the temperature central example that includes code that scans for devices and looks at the advertising data https://github.com/micropython/micropyt ... ral.py#L83
Thank you.jimmo wrote: ↑Tue Mar 17, 2020 9:48 amA BLE beacon just includes its data in the advertising payload. So you'll see this when you scan for devices (i.e. ble.gap_scan() ).
I get
ImportError: no module named 'ble_advertising'
on line
from ble_advertising import decode_services, decode_name
You need to copy ble_advertising.py to your device (it's in the same directory).
I don't understand the logic. In C routines run in main
here I see
demo() doesn't run constantly, does it?
void main(void)
Init();
while (1)
DoSomeStuff();
def demo():
ble = bluetooth.BLE()
central = BLETemperatureCentral(ble)
and so on....
if __name__ == "__main__":
demo()
Yes, exactly like your C example -- it has a while loop:
while central.is_connected():
central.read(callback=print)
time.sleep_ms(2000)
That's the problem - if it get disconnected. Isn't it better to create an endless loop? And organize some state machine - in case it's disconnected - try to connect, in case it's connected - scan for beacons.
Yes, if this were a real program, definitely.
Hi Jimmo, John7
Just followed your conversation today
Got to alternate Advertise and Scan every 5 seconds, getting Name and rssi from whoever is found
Adv works fine
The scanning gives all kind of problems like ble.gap_scan() doesn't work
Could you please inspect this code?
Thank you
Avi
code:
Adv works fine
Thank you
Avi
code:
# Advertise wait 5 second, scan wait 5 seconds, if found another BLE
# save time, name and rssi
name_found=' '
name_foundl=' '
rssi=' '
rssil=' '
_IRQ_SCAN_RESULT = const(5)
_IRQ_SCAN_DONE = const(6)
_IRQ_GATTC_DESCRIPTOR_RESULT = const(13)
_IRQ_GATTC_DESCRIPTOR_DONE = const(14)
_IRQ_GATTC_READ_RESULT = const(15)
_IRQ_GATTC_NOTIFY = const(18)
_IRQ_GATTC_INDICATE = const(19)
_ADV_IND = const(0x00)
_ADV_DIRECT_IND = const(0x01)
_ADV_SCAN_IND = const(0x02)
_ADV_NONCONN_IND = const(0x03)
class BLEA(): # Advertise
def __init__(self, name):
self.name = name
self.ble = ubluetooth.BLE()
self.ble.active(True)
self.advertiser()
def advertiser(self):
name = bytes(self.name, 'UTF-8')
self.ble.gap_advertise(100, bytearray('\x02\x01\x02') + bytearray((len(name) + 1, 0x09)) + name)
class BLEF:
def __init__(self, ble):
self._ble = ble
self._ble.active(True)
self._ble.irq(self._irq)
self._reset()
def _reset(self):
# Cached name and address from a successful scan.
self._name_found = None
self._addr_type = None
self._addr = None
self.rssi = None
def _irq(self, event, data):
if event == _IRQ_SCAN_RESULT:
addr_type, addr, adv_type, rssi, adv_data = data
return data
# Find a device advertising the environmental sensor service.
def scan(self, callback=None):
self._addr = None
self._scan_callback = callback
self._ble.gap_scan(2000, 5000, 5000)
if __name__ == '__main__':
print('advertise')
BLEA('ahp01')
time.sleep_ms(5000)
print('find')
BLEF(ble)
print('results',name_found,rssi)
time.sleep_ms(5000)
Reason: Add [code] formatting
