I working on project and I am trying to get two STM32F767 Nucleo-144 to communicate through CAN bus. Nevertheless I cannot get them to communicate, I made the following circuit using MCP2551 :
https://drive.google.com/open?id=1GnbpI ... K_Wzlt8DIk
I flashed micropython using Dfuse from STMicroelectronics. The following code is on the transmitting microcontroller:
# main.py
from pyb import CAN
led = pyb.LED(3)
led.toggle()
pyb.delay(500)
can = CAN(1, CAN.NORMAL, extframe=True, prescaler=8, sjw=4, bs1=13, bs2=13)
can.send('1', 123)
pyb.delay(500)
from pyb import CAN
led = pyb.LED(3)
aled = pyb.LED(2)
can = CAN(1, CAN.LOOPBACK, extframe=True, prescaler=8, sjw=4, bs1=13, bs2=13)
(idr, isRTR, filterMatchIndex, telegram) = can.recv(0)
if idr == 123 :
aled.toggle()
print("NOT working")
except:
led.toggle()
https://drive.google.com/open?id=1_gD6p ... KEOfU6ZlxP
Communication between two Arduinos is fine because they use the same libraries but even after playing around with the bit timing I did not manage to get the Arduino to read the right message and the right ID from the Nucleo board because I did not manage to find information on the bit timing from the mcp_can.h libraries.
https://drive.google.com/open?id=1WZuel ... 6DaoSxw1Q4
https://drive.google.com/open?id=1Ay_OM ... UVx0p-zO_Y
Something that I noticed is when I connect both Nucleo boards on the CAN bus in ''NORMAL'' mode with the command can = CAN(1, CAN.NORMAL, extframe=True, prescaler=8, sjw=4, bs1=13, bs2=13), then the CAN bus is silent having CANH and CANL remaining at 2.5V.
I would really appreciate some advice to continue on this project.
Stay healthy,
Niels
