ESP32, MQTT, and LED temperature trigger
Ivanhosa13
Post by Ivanhosa13 » Fri Apr 10, 2020 10:11 pm
Hello everyone,
i am trying to use a WS2812B LED strip to work with a code that i have for the esp32. the code is a MQTT subscription code that subscribe to a temperature topic that i run on another ESP32. in this code if the temperature get higher than a certain degree, it will print a danger message. but what i need help with is to connect the led strip to esp32 and make the led turn on whenever the temperature get higher than a certain degree. also is it possible to run the LED strip using just the esp32?
here is the code:
from umqtt.robust import MQTTClient
SERVER = '172.20.10.11'  # MQTT Server Address (Change to the IP address of your Pi)
CLIENT_ID = 'ESP32_2'
TOPIC = b'temp_humidity'
def sub_cb(topic, msg):
    print((topic, msg))
    if float(msg.decode().split(",")[0])>30:
        print("danger")
c = MQTTClient(CLIENT_ID, SERVER)
c.DEBUG = True
c.set_callback(sub_cb)
if not c.connect(clean_session=False):
    print("New session being set up")
    c.subscribe(TOPIC)
while 1:
    c.wait_msg()
c.disconnect()
VicLuna
Re: ESP32, MQTT, and LED temperature trigger
Post by VicLuna » Sat Apr 11, 2020 9:03 am
Yes of course you can switch ON your LED strip.
I guess that you LED strip is 220 AC power, so you need to add a relay for it.
This relay you should connect to a pin.out that it's subscribe to a topic.
this topic could be something like /led and you send a message 'on' or 'off' something like this:
global led
print((topic, msg)) this is just for checking.
if msg == b'on':
led.value(0)
elif msg == b'off':
led.value(1)
where led is the pin of your relay.
Post by jimmo » Tue Apr 14, 2020 5:49 am
Yes. See http://docs.micropython.org/en/latest/e ... xel-driver
Note that you will need to power the strip from 5V, not 3.3V. I also recommend using a level shifter to convert the ESP32 pin (3V) to the WS2812 input (5V).
The OP mentioned that it's a WS2812 (i.e. NeoPixels) so likely this is not the case.
Ivanhosa13
Post by Ivanhosa13 » Fri Apr 17, 2020 7:51 pm
Thank you for your response, I have a question, for the wiring, the LED strip has three wires. The ground, 5v input, and Di . Where do I connect the Di in my esp32 (DEVKIT V1) regarding to the example you Provided it. I really appreciate your help.
Post by jimmo » Fri Apr 17, 2020 11:38 pm
In that example it's connected to GPIO 0.
pin = Pin(0, Pin.OUT)
You should probably use a level shifter, but I've heard people say it works without.
Ivanhosa13
Post by Ivanhosa13 » Fri Apr 17, 2020 11:45 pm
The GPIO 0 is the same as the ground pin in my esp32 I think. Do I connect the ground also to it.
Post by jimmo » Fri Apr 17, 2020 11:46 pm
No it's not the same.
You can use pretty much any pin though, just change the code.
Ivanhosa13
Post by Ivanhosa13 » Fri Apr 17, 2020 11:47 pm
Okay thank you
