import sys
import os
from umqtt.robust import MQTTClient
random_num = int.from_bytes(os.urandom(3), 'little')
mqtt_client_id = bytes('client_' + str(random_num), 'utf-8')
ADAFRUIT_LINK = b'io.adafruit.com'
ADAFRUIT_USERNAME = b'rodrigo1120'
ADAFRUIT_KEY = b'AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA'
ADAFRUIT_FEEDNAME1 = b'gpio16'
ADAFRUIT_FEEDNAME2 = b'gpio2'
ssid = "WIFI-SSID"
password = "WIFI-PASSWORD"
client = MQTTClient(client_id= mqtt_client_id,
server= ADAFRUIT_LINK,
user=ADAFRUIT_USERNAME,
password=ADAFRUIT_KEY)
mqtt_feedname1 = bytes('{:s}/feeds/{:s}'.format(ADAFRUIT_USERNAME, ADAFRUIT_FEEDNAME1), 'utf-8')
mqtt_feedname2 = bytes('{:s}/feeds/{:s}'.format(ADAFRUIT_USERNAME, ADAFRUIT_FEEDNAME2), 'utf-8')
def connect_to_ap():
wlan.active(True)
if not wlan.isconnected():
print('Connecting to {}'.format(ssid))
wlan.connect(ssid, password)
while not wlan.isconnected():
pass
print('Credentials: ', wlan.ifconfig())
client.connect()
except Exception as e:
print('Could not connect to MQTT Server {}{}'.format(type(e).__name__, e))
def callback_routine(feed, msg):
print('Received Data from: feed={}, msg={}'.format(feed, msg))
if ADAFRUIT_FEEDNAME1 in feed:
action = str(msg, 'utf-8')
if action == 'ON':
pin16.value(0)
pin16.value(1)
print('Action: {}'.format(action))
if ADAFRUIT_FEEDNAME2 in feed:
if action == 'ON':
pin2.value(0)
pin2.value(1)
pin16 = Pin(16, Pin.OUT)
pin2 = Pin(2, Pin.OUT)
pin16.value(1)
pin2.value(1)
def main():
connect_to_ap()
client.set_callback(callback_routine)
client.subscribe(mqtt_feedname1)
client.subscribe(mqtt_feedname2)
client.wait_msg()
except KeyboardInterrupt:
print('Ctrl+C pressed, exiting')
client.disconnect()
sys.exit()
if __name__ == '__main__':
main()
Here is a picture of my serial monitor with this problem: (I took this picture 15 minutes after I stopped using the adafruit IO switches)
