You should be able to ping your pyboard. And in the frozen bytecodr of flash there shoul be uping.
from uping is import ping
ping (ip_address)
PyBoard 1.1 and WIZnet 850io
Re: PyBoard 1.1 and WIZnet 850io
Sorry, you lost me. uping is a MicroPython module, so you aren't referring to pinging *to* the PyBoard from the desktop, you are showing code for pinging *from* the PyBoard. Right?
You can always ping to the pyboard, but with the uping module you can also ping from the pyboard.
I just discovered that. Thanks. I put the PyBoard with its now-working ethernet on my home network, and then put an ESP-01S on my home network via wifi, and I was able to ping to the ESP-01S from the PyBoard even though one device was on ethernet and the other on wifi. That's super cool.
And of course, they both have access to the rest of the world too.
Nifty.
Nifty.
