good use of MICS-6814 sensor (gaz) ?
IHOXOHI
Post by IHOXOHI » Fri May 15, 2020 6:52 am
I'm using a MICS-6814 sensor (from china) which indicate 3 gaz concentrations (N02, NH3 and CO) by a analog sensor... on a pyboard.
Output voltages are very lows.
So, I use a ADS1115 amplificator. The result looks good.
But, I have interrogations about NO2 sensor.
The datasheet of the sensor : https://www.sgxsensortech.com/content/u ... -rev-8.pdf
My simple code :
from machine import I2C
from ads1x15 import *
from time import sleep
i2c = I2C(2)
adc = ADS1115(i2c = i2c, address = 72, gain = 4)
    value_no2 = adc.read( rate=0, channel1=0 )
    value_nh3 = adc.read( rate=0, channel1=1 )
    value_co = adc.read( rate=0, channel1=2 )
    print("NO2brut= ", value_no2)
    print("NH3brut= ", value_nh3)
    print("CObrut= ", value_co)
    no2_volt = value_no2 * (0.512/32767)
    nh3_volt = value_nh3 * (0.512/32767)
    co_volt = value_co * (0.512/32767)
    print("NO2volt= ", no2_volt, "volt")
    print("NH3volt= ", nh3_volt, "volt")
    print("COvolt= ", co_volt, "volt")
    no2 =  (10) * (value_no2 * (0.512/32767))
    nh3 = (100) * (value_nh3 * (0.512/32767))
    co = (1000) * (value_co * (0.512/32767))
    print("NO2= ", no2, "ppm")
    print("NH3= ", nh3, "ppm")
    print("CO= ", co, "ppm")
    sleep(10)
So, results looks goods, but I don't understand the fact that the no2 sensor have a resistor wich get down with an increase of concentration, reverse for 2 others sensor and, in final only the same calcul of concentration looks working for all sensors?
Moreover, I can't display the result on the lcd160cr... a i2c conflict with ads1115? If someone known a solution for display result from ads1115?
Thanks.
IHOXOHI
Re: good use of MICS-6814 sensor (gaz) ?
Post by IHOXOHI » Fri May 22, 2020 11:01 am
Everything is resolved...
This script looks works fine with lcd160 too...
import lcd160cr
i2c = I2C(2)
lcd = lcd160cr.LCD160CR('X')
lcd.set_orient(lcd160cr.LANDSCAPE)
lcd.set_text_color(lcd.rgb(0, 0, 255), lcd.rgb(0, 0, 0))
lcd.set_font(1, scale=1)
    value_no2 = adc.read( rate=0, channel1=2 )
    value_co = adc.read( rate=0, channel1=0 )
    no2 =  value_no2 * (10*(0.512/32767))
    nh3 = value_nh3 * (500*(0.512/32767))
    co = value_co * (1000*(0.512/32767))
    no2 = round(no2, 3)
    nh3 = round(nh3, 3)
    co = round(co, 3)
    no2 = str(no2)
    nh3 = str(nh3)
    co = str(co)
    lcd.erase()
    lcd.set_pos(0, 0)
    lcd.write("NO2= ")
    lcd.write(no2)
    lcd.write("ppm")
    lcd.set_pos(0, 20)
    lcd.write("NH3= ")
    lcd.write(nh3)
    lcd.write("ppm")
    lcd.set_pos(0, 40)
    lcd.write("CO= ")
    lcd.write(co)
    lcd.write("ppm")
    sleep(1)
    sleep(1)
I think that values aren't perfectly exacts, but not very far from reality... Maybe I'm completly wrong...
If somoene has an advise for values 's calculation....
I have tested this china sensor with ad1115 and arduino without success... Arduino need a sensor with i2c connection. I think resolution coulden't be as well as with ad1115...
Enjoy!
