Problem with Newline if i sending textfiles with udp-socket
Stefan72
Post by Stefan72 » Sun May 17, 2020 12:10 pm
i am new with MicroPython and i would like to convert my Script written in LUA to Micropython.
With this i would like to send a Text-File from my own Windows-Application to the ESP8266 and write them down to the Flash.
I open a socket and waiting for incomming Data
s_udp = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s_udp.bind(("", 4005))
    data, addr = s_udp.recvfrom(1024)
    if Debug:
        print("(Debug): received:", data, "from:", addr)
 ... do something with data ......
My Problem is, it looks like that Micropython is changing the 2 Newline-Bytes from original $0d$0a to \r\n ! If i write this to Flash then it is not identical with that File that i am sending.
This is my Testfile
this is a testfile to show my Problem with Newline !
Best Regards
This is what i get in data
(Debug): received: Hello,\r\n\r\nthis is a testfile to show my Problem with Newline !\r\n\r\nBest Regards\r\n' from ('192.168.1.10', 53963
What should i do to receive the File correctly ? With my Lua-Script it does !
Best Regards
Stefan
Christian Walther
Re: Problem with Newline if i sending textfiles with udp-socket
Post by Christian Walther » Sun May 17, 2020 5:16 pm
Are you sure you quoted that debug output exactly? The (lack of) quotes and parentheses look suspicious.
What I get is something like
(Debug): received: b'Hello\r\nWorld' from: ('192.168.0.101', 58309)
Note the b, which indicates that this is a bytes, not a string. print() prints those as their repr(). If you want to print the contents as a string, you need to convert it first: str(data, 'utf-8'). For saving to a file though, bytes are exactly what you need.
In other words, in all likelihood everything is correct with what you receive. Try printing len(data) too and you’ll see that those \r and \n are just one byte each.
SpotlightKid
Post by SpotlightKid » Sun May 17, 2020 8:10 pm
Also, make sure that you open the file to write the data to in binary mode:
with open("myfile.bin", "wb") as fobj:
    fobj.write(data)
Stefan72
Post by Stefan72 » Sun May 17, 2020 10:02 pm
@Christian
You are absolutly right. I removed the 'b from the Output because i was thinking it has nothing to do with my problem. I didn't know what it means. :oops:
@SpotlightKid
I am opening the File in binary-mode
TempFile = open('sysupdate.tmp', 'wb')
i am writing with
TempFile.write(buffer)
buffer is the parameter of a function that writes the received File in chunks of 1024 bytes. I call it from the main-routine with
functionname(data)
after all chunks are received i close the file.
TempFile.close()
My Problem is, if i download the written file sysupdate.tmp from the ESP8266 it looks like the same as the Print-Output
There is not the original $0d$0a in the File rather \r\n ! What i am doing wrong ?
I hope you can understand my problem, my english is not perfect.
Best Regards
Stefan
Post by dhylands » Mon May 18, 2020 5:46 am
b’\x0d’ is the same as b’\r’ and b’\x0a’ is the same as b’\n’
Micropython (and python) always use the shortest representation when printing.
Stefan72
Post by Stefan72 » Mon May 18, 2020 7:16 am
Hello dhylands,
i know what you say. And #13#10 is the same as $0d$0a and the same as \r\n !
But if i write the received Data to a File, which came with $0d$0a from the original source file, micropython change this to \r\n\.
If i open the source file with a Texteditor it looks like....
Best Regards
With a Hex-Editor i see the $0d$0a at the End of every Line
If i open the received File from the ESP8266 with a Texteditor it looks like ....
This is not the same File anymore ! But why ?
If i do this with nodemcu and my Lua-Script it works like it should. Sendfile and Receivedfile are identical.
Best Regards
Stefan
