I have ESP23 dev kit with micropython firmware XX.
I also have ds18b20 waterproof sensor (datasheet link: https://datasheets.maximintegrated.com/ ... S18B20.pdf
I wrote this code for it:
import time, onewire, ds18x20, machine
ds_pin=Pin(19)
ds_sensor = ds18x20.DS18X20(onewire.OneWire(ds_pin))
roms = ds_sensor.scan()
print(rom)
bytearray(b'(\xbcN6\x14\x19\x01\xba')
I used manual here https://randomnerdtutorials.com/micropy ... 2-esp8266/
Today I bought two more ds18x20 waterproof sensors (I don’t know what type of sensor - ds18a20/ds18b20 or else - are they, ‘cause eager chinese manufacturers sealed sensors inside metal bullet too good, so I can’t just look inside).
I tried to run the same code with them, but it returned the following:
bytearray(b'(\xff\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xfe\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xfc\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xf8\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xf0\xff\xff\xff\xff\xff\xff')
bytearray(b'(\xd0\xff\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xff\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xfe\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xf6\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xe6\xff\xff\xff\xff\xff')
bytearray(b'(\x90\xc6\xff\xff\xff\xff\xff')
bytearray(b'(\x90\x86\xff\xff\xff\xff\xff')
bytearray(b'(\x90\x86\xfd\xff\xff\xff\xff')
bytearray(b'(\x90\x86\xf9\xff\xff\xff\xff')
bytearray(b'(\x90\x86y\xff\xff\xff\xff')
bytearray(b'(\x90\x86y\xfe\xff\xff\xff')
bytearray(b'(\x90\x86y\xfa\xff\xff\xff')
bytearray(b'(\x90\x86y\xf2\xff\xff\xff')
bytearray(b'(\x90\x86y\xe2\xff\xff\xff')
bytearray(b'(\x90\x86y\xa2\xff\xff\xff')
bytearray(b'(\x90\x86y\xa2\xfd\xff\xff')
bytearray(b'(\x90\x86y\xa2\xf9\xff\xff')
bytearray(b'(\x90\x86y\xa2\xf1\xff\xff')
bytearray(b'(\x90\x86y\xa2\xe1\xff\xff')
bytearray(b'(\x90\x86y\xa2\xc1\xff\xff')
bytearray(b'(\x90\x86y\xa2\x81\xff\xff')
bytearray(b'(\x90\x86y\xa2\x01\xff\xff')
bytearray(b'(\x90\x86y\xa2\x01\xfb\xff')
bytearray(b'(\x90\x86y\xa2\x01\xf3\xff')
bytearray(b'(\x90\x86y\xa2\x01\xe3\xff')
bytearray(b'(\x90\x86y\xa2\x01\xc3\xff')
bytearray(b'(\x90\x86y\xa2\x01\x83\xff')
bytearray(b'(\x90\x86y\xa2\x01\x03\xff')
bytearray(b'(\x90\x86y\xa2\x01\x03\xfe')
bytearray(b'(\x90\x86y\xa2\x01\x03\xfc')
bytearray(b'(\x90\x86y\xa2\x01\x03\xdc')
bytearray(b'(\x90\x86y\xa2\x01\x03\\')
What can be done? Is the problem with code, or the sensors are failed somehow?
