IDF v4.0.1 git hash 4c81978a3e2220674a432a588292a4c860eef27b
error....
nts/wpa_supplicant/src/crypto/crypto_ops.o /mnt/c/tpi-dev/IDF4.0.1/esp-idf/components/wpa_supplicant/src/crypto/crypto_ops.c
/mnt/c/tpi-dev/IDF4.0.1/esp-idf/components/wpa_supplicant/src/crypto/crypto_ops.c:54:41: error: 'ccmp_decrypt' undeclared here (not in a function); did you mean 'aes_decrypt'?
.ccmp_decrypt = (esp_ccmp_decrypt_t)ccmp_decrypt,
aes_decrypt
Has anyone built using 4.0.1?
Build micropython with IDF v4.0.1 error
Re: Build micropython with IDF v4.0.1 error
- 2020-06-04 11_18_03-esp32_ Update IDF v4.0 supported hash. by jimmo · Pull Request #5851 · micropyth.png (68.03 KiB) Viewed 2025 times
Built micropython with...
ESP-IDF v4.0.1 4c81978a3e2220674a432a588292a4c860eef27b
micropython 1e6d18c915ccea0b6a19ffec9710d33dd7e5f866
and esp32/Make file updated to fa2c8f1ef8687aa4025f2fbbc7333ae925363585 (11hr ago as of post)
Issue....
if event == _IRQ_SCAN_RESULT: not passing
event is returning 5 and _IRQ_SCAN_RESULT = 16
Reason for up upgrading IDF was to hopefully fix... ble scan stop unexpectedly problem.
Issue....
FYI... somewhere along the line
_IRQ_SCAN_RESULT = const(1 << 4) changed to cont(5) and
_IRQ_SCAN_COMPLETE = const(1 << 5) changed to cont(6)
