Memory allocation and deallocation
elliotwoods
Re: Memory allocation and deallocation
Post by elliotwoods » Mon Jul 13, 2020 12:10 pm
Ok looking at the source code more, it looks like memory allocated in the standard ways (e.g. malloc) shouldn't be affected by the garbage collector (the gc uses a malloc at the start of run to make its own block of memory 'the heap')
investigating..
elliotwoods
Post by elliotwoods » Mon Jul 13, 2020 12:49 pm
I'm still having issues with memory that's allocated with malloc
From the other comments, it sounds like memory allocated using the standard functions (e.g. new and malloc) can still be affected. Is this true?
elliotwoods
Post by elliotwoods » Mon Jul 13, 2020 1:32 pm
hi all
i see the same issue with
uint8_t heapAreaGlobal[2 * 1024 + alignment];
i.e. when memory is defined statically at the top of the cpp file, it is still (somehow) affected by the garbage collector
let me explain what happens:
1. Allocate a section of memory to store tensors, objects, models, etc (this is called tensorArena)
2. Execute the model (invoke) 100 times. In the debugger, I see that tensorArena does not change between calls.
3. Garbage collect
4. Execute the model more times. From here, I can see that the memory in the tensorArena starts to change between every call
5. After a few calls (e.g. 5) I get a read access violation from a method being called on an object which is now a nullptr
Note : the calls are being made from a loop in Python, so there is some allocation happening between each call to make the return objects
If any of you want to see, here's a link to the code as it is right now:
https://github.com/elliotwoods/micropyt ... tensorflow
* Model.cpp (tensorflow wrapper cpp object)
* extern.c (export all the actions on Model.cpp into C syntax)
* module.c (micropython code)
Thank you
Elliot
P.S. it's really great to be able to use the windows port and debug with Visual Studio!!
Post by pythoncoder » Mon Jul 13, 2020 3:03 pm
Since nobody more knowledgeable has responded, I'll chip in. Be warned, I haven't studied the code and the following is based on things I've read over the last six years.
The GC operates only on the Python heap. This is malloc'd permanently before the bytecode interpreter and GC starts. The GC can't operate on other malloc'd areas because these will contain arbitrary data. As you've pointed out, the GC couldn't distinguish pointers from code and data anywhere other than in the Python heap.
The heap contains bytecode, integers, floats and pointers. All are constrained to 30 bits, with the remaining 2 bits used to distinguish between these types. Pointers are inherently constrained by microcontroller RAM sizes/address spaces.
The GC can then reliably operate. Somewhere there is documentation on how this is done: I rather think it's not how you might expect. The main consequence for Python coders is the early transition from small to large ints and the loss of FP precision.
Post by dhylands » Mon Jul 13, 2020 5:59 pm
Right - if you allocate something in C land (using malloc or whatever) then a pointer to that object either needs to be stored inside a python object or needs to be stored someplace in the root pointers area or the garbage collector will consider the alloced memory to be "unused" and will free it the next time that gc_collect is called.
Post by Roberthh » Mon Jul 13, 2020 8:38 pm
@dhylands. Does that also apply to storage allocated in C-land with malloc() and only used in C-Land, especially never used for a Python object? The how should the garbage collector get hold of it? My impression and experience with crashes was, the trouble start as soon as you mix these memory management domains.
Post by dhylands » Mon Jul 13, 2020 10:38 pm
Hmm. So I took a closer look at this and it looks like malloc will go thru to the underlying OS malloc (for those ports which have an underlying OS). For the bare-metal ports, malloc doesn't appear to exist at all.
m_malloc gets mapped to gc_alloc inside the py/malloc.c file.
So if there is an underlying OS which provides malloc, then it will allocate outside of the micropython heap and won't be gc'd.
elliotwoods
Post by elliotwoods » Tue Jul 14, 2020 9:47 am
Thanks all
So we can confirm that the GC shouldn't touch memory which is created by the platform's own malloc (e.g. ESP32 heap_caps_malloc).
I am getting an issue with this memory becoming corrupted after GC sweeps, and I presume there's something 'indirect' going on.
My next step is to trace down how this is happening. I'm going to spend some time with the VS debugger looking for the exact place and time the memory is changed. I don't have time to check this today so will get back soon on this. (again, thankfully I can recreate the memory issue on the windows port, so it becomes much easier to debug).
Thank you all for your responses, it's extremely helpful
Elliot
Post by pythoncoder » Tue Jul 14, 2020 3:32 pm
...For the bare-metal ports, malloc doesn't appear to exist at all.
m_malloc gets mapped to gc_alloc inside the py/malloc.c file...
Does that mean that, on bare-metal ports, C allocates memory from the Python heap?
If so, you must have to take steps to ensure that the GC "knows" this, presumably by creating a Python root pointer to the block and removing the pointer when it's deallocated. Or is this done automagically?
Post by dhylands » Tue Jul 14, 2020 4:42 pm
The python heap is the only heap available on the bare metal ports. The code would need to call m_malloc (which comes from the python heap). Calling malloc should result in a linker failure.
You would need to take steps to ensure that the pointer to the m_malloc allocated object is referenceable via the root pointers (i.e. either directly in the root pointers or stored inside an object which is reachable via the root pointers).
On the STM32 port, the root pointers are found here:
https://github.com/micropython/micropyt ... #L312-L345
For example, line 329 is the root pointers for the timers.
This line is where the timer object is allocated from the heap: https://github.com/micropython/micropyt ... mer.c#L902 and then on line 911 it stores that pointer in the root pointer structure (line 329 from mpconfigport.h)
