Using sockets but keep getting syntax error.
kiltedpython
Post by kiltedpython » Thu Jul 16, 2020 11:04 pm
Just need some basic http stuff but cannot seem to get some hidden syntax error. Any help is appreciated.
import socket
def http_get(url):
    _, _, host, path = url.split('/', 3)
    addr = socket.getaddrinfo(host, 8060)[0][-1]
    s = socket.socket()
    s.connect(addr)
    s.send(bytes('GET /%s HTTP/1.0\r\nHost: %s\r\n\r\n' % (path, host), 'utf8'))
        date = s.recv(100)
        if data:
            print(str(data, 'utf8'), end='')
            break
    s.close()
def http_post(url):
    s = socket.socket()
    s.connect(addr)
    s.send(bytes('POST /%s HTTP/1.0\r\nHost: %s\r\n\r\n' % (path, host), 'utf8'))
        date = s.recv(100)
        if data:
            break
    s.close()
Re: Using sockets but keep getting syntax error.
Post by jimmo » Fri Jul 17, 2020 4:51 am
I can't see any reason for a SyntaxError, however on line 12 you have
date = s.recv(100)
which should be "data"
Also, I'd recommend using the "urequests" library if possible.
kiltedpython
Post by kiltedpython » Fri Jul 17, 2020 2:37 pm
Thanks for the spelling fix but still seeing syntax error.
MicroPython v1.12-2 on 2020-05-01; linux version
Use Ctrl-D to exit, Ctrl-E for paste mode
>>> import pyokuets
>>> http_get(http://192.168.1.8/query/apps)
  File "<stdin>", line 1
SyntaxError: invalid syntax
There is no information on why or what. Just poke and guess?
As far as using urequests; the board that is being used does not have 'upip' or many libs installed by default. Trying to build an image for the board that will have all the libs that would be nice to have but until then going with 'sockets' for this.
Post by dhylands » Fri Jul 17, 2020 2:56 pm
You need to surround the argument to http_get in quotes.
kiltedpython
Post by kiltedpython » Fri Jul 17, 2020 6:11 pm
Thank you so much. That was the ticket. :)
