Hi Everybody!
I have a simple question concerning the pyboard. I want to use it with an external powerbank. It works fine, but the pyboard is just too efficient and not drawing enough power, so the powerbank thinks it is not used and goes into standby mode after 30 sec (and switch off the pyboard).
What could I do to draw more power?
1. I read on an arduino forum, to connect a 470 Ohm resistor from voltage to GND. Is this safe? If yes, should I use 3V3 or V+? The pyboard is out of stock and I really don't want to break it.
2. Or should I prefer doing some silly calculations in the background to increase cpu load?
Thanks in advance,
Vince
UPDATE: I'm using a pyboard V1.1, the powerbank is an Intenso Powerbank XS10000
[SOLVED] Prevent powerbank to go into standby mode
Re: Prevent powerbank to go into standby mode
It's usually ok to create power peaks onec and a while to keep the power bank happy.
This is a pretty naive way to create power consumption peaks, but it shows the idea.
Note:
If you run your pyboard at a low processor clock it might not reach an adequate power level to keep your power bank happy.
def wup(p):
for i in range(1000):
pass
rtc.wakeup(10000, wup)
Note:
I have encountered that one. The amount of current you need to draw depends on the design of the powerbank. You haven't said what type of Pyboard you have but on the assumption that it's a V1.0, V1.1 or Pyboard Lite the V+ pin is connected to USB 5V through a diode so you can safely draw power from there. I use 100Ω to draw just under 50mA. If that isn't enough, try 47Ω.
Hi pythoncoder,
your solution worked! Thank you very much.
First I tried with 100Ohm, but it didn't work. Then I tried with 50Ohm (5x10Ohm), and this worked!
I will buy a ~50Ohm resistor asap and try again.
I should point out that the 50Ω (or 47Ω) resistor should be rated at 0.5W or above.
