Elegant Physical Config for Pyboard D
Hey all,
I've been tinkering with esp32's for a while now, but I'm starting to see the light with the sheer speed benefits of the tasty stm32 on my pyboard D.
I'm just wondering how on earth people are actually physically handling the i/o for this teeny device. It's so beautifully designed and made, that it seems a great sin to be soldering anything directly to it. Would love to hear from anyone how they've gone about actually connecting things to it for prototyping/general tinkering (rather than custom DIP interface pcb, for example) & any links/pics would be greatly appreciated.
Cheers
Cheers
Re: Elegant Physical Config for Pyboard D
I use the WBUS-DIP28. There is also a DIP68 but this is rather large for some projects. There was discussion on the notion of a DIP32 adaptor which simply brought out the pins on the D series edges to a breadboard friendly format, but my requests for updates on this have drawn a blank so I don't think this is going ahead.
I have considered DIY but the mechanical alignment for the WBUS connectors troubles me.
For projects powered by USB and/or LiPo the DIP28 works well. But it only brings out a subset of the Pyboard edge pins, it doesn't readily support use with a custom PCB with 5V power, and for many applications the power control circuitry is redundant. Hence the DIP32 idea.
I used the DIP28 and a custom DIP interface PCB when I need the pins not available at the DIP28. The DIP68 is way too large. A simple DIP32 which brings out all edge connectors would be fine.
That sounds interesting. It sounds like you've invented the DIP32 Does it connect to the D using the wbus connectors?
No, it does not use the D Bus connectors. That is too hard for me to make, with the tight requirement for tolerances. My board just stick to 1/20" female pins soldered to the top of the PyBoard D. I had sent you an item of that board. Not beautiful, but it works.
Hi Roberthh,
can you post a picture ?
Regards,
Regards,
Attached are two pictures. The Kicad files are here: https://github.com/robert-hh/PYBD-Adapter
- IMG_20201102_165945706.jpg (97.28 KiB) Viewed 5464 times
- IMG_20200305_104455025.jpg (87.43 KiB) Viewed 5464 times
Nice !
Thank you
Thank you
Ah! That's exactly what I'm after. Thanks for posting the kicad files tooRoberthh wrote: ↑Mon Nov 02, 2020 4:09 pmAttached are two pictures. The Kicad files are here: https://github.com/robert-hh/PYBD-Adapter
That is excellent.
I didn't know you could get headers with 1.27mm pitch. Are these widely available?
