Log entire REPL prompt to SD
Is there a way to log the entire REPL prompt to SD? I want to log the entire prompt rather than just an individual event/error. I am using the PYBD-SF6W with an SD card.
Re: Log entire REPL prompt to SD
Can you explain what you mean by "log the entire REPL prompt".
If what you mean is something like: create a text file, the contents of which look exactly like the interactive REPL session, then yes you can do this with dupterm.
I haven't tested this, but the rough idea is to make a stream that you pass to os.dupterm, and every time MicroPython writes to stdout, it also will be sent to your stream. See https://github.com/micropython/micropyt ... rt_repl.py for an example of how we use this to make a REPL over BLE.
This is untested, but this is a sketch of a stream that only handles writes and could log all the writes to a file, and how to register it with dupterm.
import os
class LoggingStream(io.IOBase):
def __init__(self, path):
# open file
def read(self, sz=None):
return None
def readinto(self, buf):
return 0
def ioctl(self, op, arg):
return 0
def write(self, buf):
# write buf to file
os.dupterm(LoggingStream(path))
Thank you providing this information. I am a bit novice with respect to micropython, so I was wondering if you might be able to show me how this could be implemented? I read through the link you attached, but I'm not sure how much of that code would translate to my issue.
Basically, I am experiencing errors with my device (which is being used to control a couple of Dynamixel motors) exclusively when I am running from an external power supply and not connected to my PC via the microUSB port. So when an error/failure occurs, I cannot view it in real time since I cannot see the REPL prompt. So, I want to record/store on SD everything that would have been printed to the REPL prompt had I been connected via microUSB to the PC.
Is there the ability to view the REPL prompt wirelessly on the PYBD-SF6W? I am noticing that an error gets returned on my PYBD-SF6W saying that os module has no module dupterm. I've tried both os and uos. I noticed that others had a similar issue on ESP32 boards: viewtopic.php?t=3997.
With WebREPL, yes.
That's weird. Can you check what firmware version you have?
If you connect to the REPL, you should see something like (except likely a different build of v1.13).
MPY: sync filesystems
MPY: soft reboot
MicroPython v1.13-160-ga9ed9e58d-dirty on 2020-11-04; PYBD-SF6W with STM32F767IIK
>>> import os
>>> os.dupterm(None)
Yeah, this sounds like a good idea and definitely should be possible.kbrenner wrote: ↑Wed Nov 04, 2020 7:42 pmBasically, I am experiencing errors with my device (which is being used to control a couple of Dynamixel motors) exclusively when I am running from an external power supply and not connected to my PC via the microUSB port. So when an error/failure occurs, I cannot view it in real time since I cannot see the REPL prompt. So, I want to record/store on SD everything that would have been printed to the REPL prompt had I been connected via microUSB to the PC.
The other simpler option is just to use try/except handlers and write any exception details directly to a file:
except ...:
with open('error.log', 'w') as f:
f.write(...)
Here's a full example: https://gist.github.com/jimmo/a96f8cde2 ... 15c85e25ddkbrenner wrote: ↑Wed Nov 04, 2020 7:42 pmThank you providing this information. I am a bit novice with respect to micropython, so I was wondering if you might be able to show me how this could be implemented? I read through the link you attached, but I'm not sure how much of that code would translate to my issue.
MPY: soft reboot
>>> 1+1
2
>>> import log_sd
>>> 2+2
4
>>> log_sd.enable_logging('stdout.log')
>>> 3+3
6
>>> print('hello')
hello
>>> log_sd.disable_logging()
$ pyboard --device /dev/ttyACM0 -f cat stdout.log
cat :stdout.log
>>> 3+3
6
>>> print('hello')
hello
What I normally do in a scenario like this is to log to a UART, which can also be done by using os.dupterm
Thanks. I'm able to access the REPL prompt from WebREPL and write various python commands that I then see show up on the local REPL prompt; however, I do not see it working in the opposite direction. For example, I have a main script that looks like:
ap = network.WLAN(network.AP_IF)
ap.active(True)
count = 0
while(False):
count = count + 1
if count == 100000:
print('hello world')
count = 0
However, I do not see the print outs of 'hello world' on the WebREPL. I do see them on my local REPL.
Also, I am running v1.12.
Additionally, I have written try/except handlers; however, occasionally the Pyboard will show errors in the REPL prompt that don't come from the try/except such as:
failed 0 3 4 c (or some other combination of numbers/letters)
some memoryview error
ap.active(True)
count = 0
while(False):
count = count + 1
if count == 100000:
count = 0
