a problem with thonny or µPython???
BL007
Post by BL007 » Wed Nov 04, 2020 6:44 pm
I want open a file. This file is r.a.120kB. Because I have a ESP with 8/4MB SPI-RAM. I open the file, read it with readlines(), determinate the numbers of lines and show that in the shell. SC1
All in butter.
Maby a half minutes later the completly content of the variabe lines/file appears in the shell. The ESP hangs up(I must reset him) and the Thonny is 1 minute blocked. SC2
I suspect this is related to the size of the variable. Or ist his a problem of Thonny?
aivarannamaa
Re: a problem with thonny or µPython???
Post by aivarannamaa » Thu Nov 05, 2020 8:24 am
This is probably Thonny's fault. Please try https://github.com/thonny/thonny/releases/tag/v3.3.0b7, which shortens the repr-s of the values for the variable browser.
Actually, before you upgrade, please try whether you experience the same problem if you close the variable browser.
Aivar Annamaa
https://thonny.org
BL007
Post by BL007 » Fri Nov 06, 2020 10:33 am
Thank you very mutch!
If you are in Thuringia the next time, I owe you:
aivarannamaa
Post by aivarannamaa » Fri Nov 06, 2020 12:25 pm
Wow! I'll keep this in mind :)
Aivar Annamaa
https://thonny.org
