How do I implement serial communication? Can UART be used in a way that does not collide with REPL/webREPL?
How do I set up a listener for incoming messages from the serial port?
The ASCII-commands end all with <CR>. That means it has to read from serial until <CR> (=x0D) is received and than send this text line to MQTT.
Here is my current code. So far. Any hints are welcome:
# WLAN setup
wlan_ssid = 'mySSID'
wlan_pass = 'myPassword'
wlan.active(True)
if not wlan.isconnected():
wlan.connect(wlan_ssid, wlan_pass)
while not wlan.isconnected():
pass
print('Network: ', wlan.ifconfig())
# Serial setup
uart = UART(0, 9600)
uart.init(9600, bits=8, parity=None, stop=1)
# MQTT setup
mqttserver = '192.168.1.XX'
mqttport = 1883
mqttuser = b'mqtt'
mqttpswd = b'myMQTTpassword'
mqtt_pubtopic = 'device/pup'
mqtt_subtopic = b'device/sub'
mqttclient = MQTTClient("umqtt_client", mqttserver, mqttport, mqttuser ,mqttpswd)
# funtion for sending to mqtt
def mqtt_pub(topic, payload):
mqttclient.publish(topic, payload)
def mqtt_callback(topic, msg):
mqtt_pub(mqtt_pubtopic+'/testecho', msg)
# here comes the code to send to serial port
## #this does not work:
## print('got MQTT message:', topic, msg)
## uart.write(msg)
## msg = uart.readline()
## mqtt_pub(mqtt_pubtopic+'/ans', msg)
mqttclient.connect()
mqttclient.set_callback(mqtt_callback)
mqttclient.subscribe(mqtt_subtopic)
message = 'booting '+name
mqtt_pub(mqtt_pubtopic, message)
print("MQTT: Connected to %s, subscribed to %s topic" % (mqttserver, mqtt_subtopic))
# Non-blocking wait for message
mqttclient.check_msg()
heartbeat = not Pin(2, Pin.IN).value()
time.sleep_ms(50)
Pin(2, Pin.OUT).value( heartbeat )
time.sleep_ms(450)
# here could follow other code
