Multiple Usb HID interface
pagano.paganino
Post by pagano.paganino » Mon Jan 25, 2021 11:03 am
Hi falks,
Is possibile to implement multiple usb hid interface? Kayboard + mouse
Thanks and regards,
F.
Re: Multiple Usb HID interface
Post by jimmo » Tue Jan 26, 2021 12:56 am
Unfortunately I don't think so... the pyb.usb_mode can only be given either hid=pyb.hid_keyboard or hid=pyb.hid_mouse.
This could probably be added though -- look in stm32/usb.c
STATIC mp_obj_t pyb_usb_mode(size_t n_args, const mp_obj_t *pos_args, mp_map_t *kw_args) {
pagano.paganino
Post by pagano.paganino » Tue Jan 26, 2021 8:56 am
Reading the documentation https://www.usb.org/sites/default/files/hid1_11.pdf regarding the usb hid I found that it is possible to declare more reports but specifying a report id.
Can this feature be used in micropython?
the current implementation of the mouse and keyboard report ignore the report id (as per specification since it is only one report)
How complicated is it to implement this functionality?
https://github.com/micropython/micropyt ... hid.c#L340
https://github.com/micropython/micropyt ... id.c#L381
Thanks and regards,
F.
chuckbook
Post by chuckbook » Tue Jan 26, 2021 11:55 am
It can be done using an adequate HID descriptor.
pagano.paganino
Post by pagano.paganino » Tue Jan 26, 2021 4:16 pm
Have you tried or are you assuming it works?
chuckbook
Post by chuckbook » Wed Jan 27, 2021 11:37 am
We are using it on PYBD SW6 to emulate a combination of TOUCH & KEYBOARD. It works perfect.
pagano.paganino
Post by pagano.paganino » Thu Jan 28, 2021 10:32 am
Can you share an example of hid descriptor?
pagano.paganino
Post by pagano.paganino » Mon Feb 08, 2021 9:34 am
Can you share an example of hid descriptor and usage with send/recv?
Best regards,
F.
