If I understood right this is to make the Windows terminal window able to display colors, right? Hence when using pye, the bottom status ruban is displayed with the blueish color correctly. Is there any other reason to support VT100 commands?
sebi wrote: ↑Thu Feb 04, 2021 5:38 pm
Roberthh wrote: ↑Thu Feb 04, 2021 6:41 am
I faced the same challenge and tried all possible Ctrl-Key combination on my German Keyboard
I just did the same and came out with the `Ctrl-^` combination on my MacBook french keyboard running Windows 10 under bootcamp.
For an unknown reason `Ctrl-^` doesn't work anymore, neither any other key combination to exit properly the terminal.
I don't recall exactly what I did in the meantime, but not a lot besides rebooting my computer.
Can you tell me if it's normal that `Ctrl-C` is captured by mpr rather than the pyboard? Hence, `Ctrl-C` doesn't exit the paste mode as intended but terminates mpr with an exception. Is it the intended behavior? I don't recall how this performed when I was able to use `Ctrl-^` to exit mpr properly.
Roberthh wrote: ↑Wed Feb 03, 2021 1:55 pm
There are shortcuts in mpr.py for device names. So you can make your life easier.
I modified mpr.py with an additional shortcut for COM4 (my actual rp2 com port) thus `python mpr.py` enters the REPL directly without passing any extra argument, as I believe it scans automatically all the shortcuts ports.
I also modified the code according to your
explanations in Github so I can use `Home`/`End`/`PgUP`/`PgDown` and don't exit mpr when pressing on unknown function keys. It works great!
