A little Home Assistant Mqtt integration using mqtt_as
rguillon
Post by rguillon » Mon Feb 08, 2021 7:47 pm
Hi all,
I've made a little library allowing me to interface a esp32 with home assistant using Peter Hinch's mqtt_as.
I have implemented switches, basic lights, lights with brightness and RGB lights. Devices are automatically registered into home assistant with mqtt discovery, allowing to create automations.
I tried to make something easy to extend, allowing to implement other kind devices. I use it to drive the lights of my fish-tanks, I plan to add temperature sensors next.
The code quality is questionable as I'm still new to python, but it works.
https://github.com/rguillon/hatank
kevinkk525
Re: A little Home Assistant Mqtt integration using mqtt_as
Post by kevinkk525 » Tue Feb 09, 2021 6:09 am
That is a very nice first version!
By the way: I actually created a framework over the last few years with the exact same goal, integrating devices with home-assistant using mqtt_as with mqtt autodiscovery. It is more complex and powerful than yours, so maybe you can find some inspiration or some components you can reuse (e.g. I created climate components but have no lights, etc).
https://github.com/kevinkk525/pysmartnode
Kevin Köck
rguillon
Post by rguillon » Tue Feb 09, 2021 7:42 pm
Thanks, that looks way more advanced than mine, I will definitely have a look.
rguillon
Post by rguillon » Fri Feb 19, 2021 5:13 pm
I'm now using pysmartnode, thanks.
I ported my code into a new ComponentBase that was pretty easy to understand.
https://github.com/rguillon/pysmarttank
kevinkk525
Post by kevinkk525 » Fri Feb 19, 2021 7:15 pm
That code looks great!
I'm glad you found the process to implement your component easy.
I'm currently waiting for my adafruit dotstar (chinese clone) and your code is a great starting point for integrating a light component properly, which I haven't done before.
Kevin Köck
