dfu-to-bin-tool Linux
Hi there,
I have been using the dfuse-demo (STSW-STM32080) for converting the dfu files into bin- oder hex-files but it is replaced by STM32CubProgrammer and this tool doesn´t offer dfu-to-bin-conversion, also the STSW-STM32080 only works on Windows. So is there an alternative for the old dfu file manager and what should I use on Linux. BTW: why is the firmware offered in this format, wouldn´t it be more convenient to offer it in bin- oder hex-format?
Thanks and best regards!
cyr#
cyr#
Re: dfu-to-bin-tool Linux
I normally use pydfu.py (included with Micropython) when using linux. You could also use dfu-util.
If you're building the firmware yourself, using: will use pydfu.py by default. Here's the output (done on a Mac but linux does the same thing): and here's the same output when using dfu-util:
Note that under linux you want your user to be a member of the dialup group (may vary depending on the distribution being used).
make BOARD=PYBV11 deploy
$ make BOARD=PYBV11 deploy V=1
python3 ../../py/makeversionhdr.py build-PYBV11/genhdr/mpversion.h
GEN build-PYBV11/genhdr/qstrdefs.collected.h
python3 ../../py/makeqstrdefs.py cat qstr _ build-PYBV11/genhdr/qstr build-PYBV11/genhdr/qstrdefs.collected.h
QSTR not updated
python3 ../../tools/makemanifest.py -o build-PYBV11/frozen_content.c -v "MPY_DIR=../.." -v "MPY_LIB_DIR=../../../micropython-lib" -v "PORT_DIR=/Users/davehylands/micropython/micropython/ports/stm32" -v "BOARD_DIR=boards/PYBV11" -b "build-PYBV11" -f"-march=armv7m" boards/manifest.py
Writing build-PYBV11/firmware.dfu to the board
python3 ../../tools/pydfu.py --vid 0x0483 --pid 0xDF11 -u build-PYBV11/firmware.dfu
File: build-PYBV11/firmware.dfu
b'DfuSe' v1, image size: 361213, targets: 1
b'Target' 0, alt setting: 0, name: "ST...", size: 360928, elements: 2
0, address: 0x08000000, size: 14592
1, address: 0x08020000, size: 346320
usb: 0483:df11, device: 0x0000, dfu: 0x011a, b'UFD', 16, 0xc350b1a7
Writing memory...
0x08000000 14592 [=========================] 100%
0x08020000 346320 [=========================] 100%
Exiting DFU...
Finished
$ make BOARD=PYBV11 deploy USE_PYDFU=0 V=1
QSTR not updated
dfu-util -a 0 -d 0x0483:0xDF11 -D build-PYBV11/firmware.dfu
dfu-util 0.10
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2020 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
ID 0483:df11
Run-time device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 2048
DfuSe interface name: "Internal Flash "
file contains 1 DFU images
Please note that the next version of dfu-util will automatically
set alternate interfaces based on the DfuSe file images!
parsing DFU image 1
Target name: ST...
image for alternate setting 0, (2 elements, total size = 360928)
parsing element 1, address = 0x08000000, size = 14592
Erase [=========================] 100% 14592 bytes
Erase done.
Download [=========================] 100% 14592 bytes
Download done.
parsing element 2, address = 0x08020000, size = 346320
Erase [=========================] 100% 346320 bytes
Erase done.
Download [=========================] 100% 346320 bytes
Download done.
Done parsing DfuSe file
Hi Dave,
thanks a lot. When I make my own build it works fine, because I got all binary formats I need (.bin, .hex and .dfu) But I am looking for a simple way to upload the firmware for my students. They use the binary download files on the Micropython page. So they only got the .dfu version and they are working with STM32L476RG NUCLEO64 boards. So the easiest way (IMHO) is to convert the .dfu file into a .bin format and copy the file by drag and drop to the board.
But I can´t find a way to convert it either with pydfu.py nor with dfu-util like I can do with Dfu file manager on Windows systems. Do you have any idea?
Thanks and best regards,
Werner
Werner
I'm not sure how you would "drag and drop" a bin file. The problem with bin files is that they don't contain any information about where they're supposed to get programmed to.
You can use dfu.py with the -d option to create 2 .bin files. For example: The filesystem lives between the place that the 2 bin files get flashed to.
$ cd build-PYBV11
$ ../../../tools/dfu.py -d firmware.dfu
File: "firmware.dfu"
DfuSe v1, image size: 361213, targets: 1
Target 0, alt setting: 0, name: "ST...", size: 360928, elements: 2
DUMPED IMAGE TO "firmware.dfu.target0.image0.bin"
DUMPED IMAGE TO "firmware.dfu.target0.image1.bin"
usb: 0483:df11, device: 0x0000, dfu: 0x011a, UFD, 16, 0xc350b1a7
Hi Dave, long time ago (normally a good sign ) but now I have tried the way you proposed. I have typed in the command as you do but I got the following error message:
Werner
Do you have any idea what went wrong? Thanks in advance!server:~/micropython/tools$ python3 dfu.py -d NUCLEO_L476RG-20200902-v1.13.dfu
File: "/mnt/c/Users/werner/OneDrive/microPython/MicroPython_Firmware/STM32/NUCLEO_L476RG-20200902-v1.13.dfu"
b'DfuSe' v1, image size: 336901, targets: 1
File "dfu.py", line 160, in <module>
parse(infile, dump_images=options.dump_images)
File "dfu.py", line 42, in parse
tprefix["name"] = cstring(tprefix["name"])
File "dfu.py", line 23, in cstring
return string.split("\0", 1)[0]
TypeError: a bytes-like object is required, not 'str'
Werner
It looks like dfu.py needs a slight update:
https://github.com/micropython/micropyt ... 313dbd60e7
I created a PR to fix it:
https://github.com/micropython/micropython/pull/7931
Until then, you can edit line 23 of dfu.py and change "\0" to b"\0"
Dear Dave,
sorry for the long delay, but I checked it today and it works fine. Thank you very much for your support.
Best regards,
Werner
Best regards,
Werner
My fix was merged into master about a week ago, so if you update to the latest, you'll pick up the change automatically.
